STS problem
I thought I had an exhaust leak. No problems with the exhaust leaking. The noise is coming out the tail pipe. It sounds just like an exhaust leak. The turbo sounds like it is spooling up much faster than normal, but it does not pull hard. The rpms climb, but the power is not there. Any thoughts or suggestions.
No gauge yet. Gonna rig one up tomorrow to see what is going on. I'll also try spinning the impellers by hand. I'm sure it is spooling up. Part throttle shifting from 1-2 will bark the tires pretty good. After the shift the engine winds up but the truck does'nt pull much more than without the turbo.
Originally Posted by F8L Z71
Ahh ok./
You've gone over all the obvious stuff though like tube leaks under boost, your plugs are gapped right, fuel pressure etc?
Gonna check all the silicone couplers again this morning. The noise that sounds like an exhaust leak coming from the tail pipe has me confused. I'm wondering if one of the cats is messed up.
