STS new 1/4 mile times
Ran 13.65 100.2 mph with 2.10 60ft on the g-tech this morning in cool 30 degree weather at only 5lbs of boost through the borla muffler with 3/4 full tank of fuel. Shifting at only 5200-5300rpms.
Backed it up hot going the other way- 13.75 99.8mph 2.15 60ft.
My truck only has 6000miles and is completely full weight with spare tire and speaker box and all. These times were ran on stock tires at 25psi. leaving from idle and gradually rolling into throttle any more the boost comes on too fast and tires go up in smoke. Glad I only went with the 2600 stall.
My truck is leaning out on the top end with the stock injectors.
New injectors and tune with TM fully deleted should be in this week from Nelson. I will bump the boost up to 6-7lbs and should see mid to low 13's on street tires, bolt some drag radials on and go 12's easy.
I've never driven anything this quick and yet be this mild and quiet. With the muffler on its almost at stock sound levels. I would recommend this setup to anyone, makes a nice sleeper/daily driver.
once on boost there's probably not much difference between them though.
