STS dyno results
Those numbers seem really low for a 6.0.... even if the dyno was in AWD.
I gained ~150 rwhp on 8psi intercooled on my stock 5.3, and I think there is still alot more power left in there.
How much timing are you running? Who did the tune? and like parish8 said, were you logging on the dyno?
at 8psi, I'm at 376/400(in comparison with the mustang dyno to Dynojet) at the wheels on my 5.3, so your 6 liter should be much more IMO, being that you had 281/305 stock. I only had about 225 at the wheels with the flowmaster.... just comparing the apples and oranges.
Originally Posted by parish8
were you loging anything? what did you use for programing?
those numbers dont suprize me too much if you werent logging. you were probably seeing high IAT's and that was pulling a pile of timing and then the 13-1 a/f ratio may have let it show a little knock pulling more timing. also a higher load wich boost will show gets you into a part of the timing tables with lower numbers.
i wouldn't even bother trying to tune it without the meth, just keep that tank full.
with some tuning that thing should scream.
I agree. Might as well forget running this without the Meth. I guess if I run out some day I want to make sure I can still hammer it and be "safe"!
that tune was done pre dyno? like on the street? did you log on the dyno? if you have a log from the dyno it would probably be easy to see the problem.
the meth numbers seem decent. considering the drive line losses you must be seeing 100hp isn't too bad and i bet you could throw more than 7psi spraying meth. typicaly you can goto 7psi with hot air and i would think at least 9psi with meth. who knows, maybe 12+psi with meth.
if you are spraying pre IAT sensor it would be prety easy to tune in some safety if you ran out of meth. you can use the IAT vs timing table to pull a plie of timing if it happens to get into high AIT's wich you would never see if you spraying meth. i dont know what that cut off would be.
I didn't log on the dyno as it was at a different place just to get the hp/tq #'s. None of us were expecting the A/F to be off. Even with 7psi setting it's off. A/F was around 10.7 so there is certainly more power in it.
The reason we stopped at 7psi as the high setting is the valve float. As of Monday, I won't have to worry about that (new pushrods/springs). They were thinking 9psi would be about as high as I'd want to go. Do you think it could go higher without causing any issues with the engine??? I know the trans will blow...
i think 9psi is a good everyday setting. there is most likly more in it but i wouldn't risk it unless you want to drive around with a lap top for a few days to work your way up to the limit. i dont think you can find the limit of your set up in one tuning session and then just leave it there.
i was able to push my 4.8 up to 18psi but valve float limited me to 5400rpm or soo. i would think you could goto 12psi at least and still get to 6000rpm without float but i only have that one motor/experience to speak from.
my experinece show that if you avoid detonation COMPLETLY, you have nothing to worry about other than a tranny. i do all of my tuning based on how far i can push things before i see detonation.
if you start turning it up and get to 15psi before you see detonation then hell yeah, crank it back 2-3psi and i think you will be fine everyday.
Parish, how much of a power increase did you see for each pound of boost? I know it's dependant on each engine and there are variables. But can you give a rough guestimate? Or anyone else for that matter? I'm wondering how much more to expect with another 2-3lbs or so?
