Stroked 6.0 guys...Info request.
Old Nov 16, 2006 | 06:10 AM
  #31
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by thunder550
If I go with a full shortblock, what do you think about this?
http://texas-speed.com/shop/item.asp?itemid=46
If I put .065" head gaskets on it I think my CR will be just a hair above 9.5:1
Planning on buying a good oil pump, but other than that the rest of the stock parts should be up for the task.....I think.....
I would go that route.
Trey, you went on for half a dozen posts telling him to go a different route when he was already decided on what to do and no matter how he told you what he was doing you kept at it. Was just saying help him with his decision instead of trying to change and an already made decision. Not to mention some of the things you were saying are just flat out wrong.
Old Nov 16, 2006 | 09:52 AM
  #32
thunder550's Avatar
High on diesel fumes
Intake manifold suggestions? I think a stock truck manifold would be a restriction N/A but if it will work well once I get the turbo(s) on it then I may just go that route. Also injector size - am I going to need something more than 42#ers? How much are stock fuel rails good for (return style)?
EDIT - I started a new thread for intake/fueling selection
https://www.performancetrucks.net/fo...d.php?t=379253
Old Nov 16, 2006 | 12:46 PM
  #33
treyZ28's Avatar
heaven forbid he changed his mind before starting a project because he found something he liked better
Old Nov 16, 2006 | 06:14 PM
  #34
1slow01Z71's Avatar
GM Hi-Tech Performance August issue is what oyu are looking for they have a full 383 LS1 build with all the tools and step by step how to.
Old Nov 16, 2006 | 06:19 PM
  #35
thunder550's Avatar
Coo, thanks
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
