Stroke out My 4.8 to 5.3
Old Jun 18, 2004 | 08:21 PM
CARAZYCUTER 4.8's Avatar
Originally Posted by whitt1
Carazycutter4.8 there's absolutely no way a 4.8 or 5.3 will accomodate a 4"bore.
have you tried this? The 4.8/5.3 will accomadate the ls1 piston, there is less than a .10 difference between the ls1 & 6.0 piston. I thought that the ls1 piston was pushing it from the 4.8/5.3 piston which I believe are 3.789 bore. However there is a machine shop here in town AMS racing that says it can be done. I know the ls1 piston will work but they claim the 6.0 works. I was seriously considering allowing them to try.
Old Jun 18, 2004 | 08:24 PM
BigTex's Avatar
Find a good set of LS1 rods, pistons, and crank. Then have your 4.8 / 5.3 block bored out to 99mm. That would give you a iron block 5.7 liter motor. Only costs are the bore / hone, used LS1 rotating, and new gaskets.
Old Jun 19, 2004 | 10:35 AM
ktmrider's Avatar
Yep, the 99mm cut works great. I know cuz I just did it and have the sonic checksheet to prove it.
As far as going to 4.00", it might be a little thin. Most of the side/side bores sonic checked around 0.250" but the top/bottom ones were around 0.160". Another 0.100" might be chancy especially if you use gas or FI. General rule of thumb is no less than 0.150" of wall thickness.
The 5.3L shortie for $150 is an awesome price, IF you don't need to do much to freshen it up. The truck blocks are notorious for spinning main/rod bearings. You would only need a head/cam gasket kit then. SDPC sells them for around $250 and has all the gaskets and crank bolt.
The other route is like you thought, get a crank and rods from ANY other LS1 style motor. The 5.3, 5.7, and 6.0L motors all use the exact same crank/rod assemblies. Lots of them out there from stroker conversions. You would then only need to add some bearings to the list. If your motor is below 50K miles you can get away with re-using the original gaskets. They are rubber coated crush style that are very good and easy to reuse. Only one you may consider is the water pump pair. Cheap insurance.
Last, I have a stock 3.622" crank, 5.3L rods, and main/rod bearings if you decide to go that way. Weight would be around 60# coming from ZC 87114, NM. You can have them all for $150 plus shipping.
Old Jun 19, 2004 | 01:29 PM
dowright82's Avatar
Default Thanks A Lot!!
Lots of INFO!! Hell yeah! Thanks so much . . .
Old Jun 19, 2004 | 04:59 PM
So these guys were blowing smoke? I really appriciate that! They were telling me that it has been done, when I asked about problems they just stared at me & asked one of the machine guys in the back. When I asked about the sonic bore testing they somewhat blew me off!
Dan Neumann
11
Aug 7, 2022 09:06 AM
luis_bullz
Sep 8, 2015 03:08 AM
JordanH
Aug 8, 2015 07:59 PM
MS3Z
Jul 30, 2015 06:17 PM
06 4.8
Jul 15, 2015 07:17 PM
