Stripped intake manifold mounting hole
Old Feb 27, 2008 | 10:24 PM
chevymanLS2's Avatar
Banned
Default Stripped intake manifold mounting hole
Its the hole thats all the way in the back and to the left from the throttle body. Am I fucked or should i leave it empty or enlargen it and retap it?
Old Feb 27, 2008 | 10:29 PM
mbell's Avatar
you can always try to retap the hole usually works well
Old Feb 27, 2008 | 10:38 PM
Banned
Ya I already did that. Originally, when I mocked it up I torqued down the bolts and that one broke. I had to drill and tap it out and in the end there was few threads. When I finally bolted the intake down for the final time just now, those threads didn't hold, so now i don't no what to do.
Old Feb 27, 2008 | 10:45 PM
kbracing96's Avatar
I'd put a heli-coil in it.
Old Feb 28, 2008 | 07:21 AM
adam1803's Avatar
+1, heli-coils are the way to go especially when working with aluminum.
Old Feb 28, 2008 | 08:05 AM
Yeah man, these guys are right on with the Heli-Coil.....that's a lifesaver! You can pick up a pack at damn near any auto parts store. You simply use the Heli_coil with your drill and it basically re-taps the hole while inserting a new thread coil.
Old Feb 28, 2008 | 11:42 AM
Dark Halo's Avatar
yea seems to work well I noticed a lot a rebuilt parts use heli coils
Old Feb 28, 2008 | 12:53 PM
LowBlack99's Avatar
+1 for Heli-coil.
Old Feb 28, 2008 | 04:48 PM
Banned
Are u sure it will hold up? I know it's only being torqued down to 7 ft lbs, but it can't break.
Old Feb 28, 2008 | 05:52 PM
Red04Silverado's Avatar
Youll be fine man dont worry
