stock spring locks?
Old Apr 8, 2010 | 01:11 AM
slamdlsx's Avatar
Default stock spring locks?
need to know if i can use stock locks and retainers with silver comp 918 springs?
they came with titanium retainers but i cant get the stock locks to work with them.
any help is apreciated. thanks
Old Apr 8, 2010 | 10:20 PM
slamdlsx's Avatar
Alright guys upon further research found out i have tooled steel retainers.
I was using the cheapo spring compressor that you turn on the top and it hooks on each side. I think maybe the spring wasnt sitting center so i could only get one lock in.
Gonna try again later with the big spring compressor that you use when the heads are off.
Old Apr 9, 2010 | 01:25 AM
Ferocity02's Avatar
Yes you can use the stock locks.
Old Apr 9, 2010 | 08:33 AM
slamdlsx's Avatar
they should fit fine with the tooled retainers with my 918s? shouldnt they? cause i couldnt get them in with the tooled retainers. i think i just had a bad compressor
Old Apr 9, 2010 | 09:56 AM
Ferocity02's Avatar
See if they fit without any spring. Are they Comp retainers? I doubt they would change them so you need a different size/angle lock. But you never know these days I guess...
Old Apr 9, 2010 | 10:08 AM
TXsilverado's Avatar
all of the stock stuff will work with 918 springs. a good compressor makes life better
Old Apr 9, 2010 | 10:23 AM
slamdlsx's Avatar
yea i think they crappy compressor didnt help. im gonna try a better one this time and go again.
Old Apr 9, 2010 | 12:22 PM
neilownz's Avatar
I used a crane one, but I think someone on ls1tech sells a valve spring compressor tool that is a decent design.
https://ls1tech.com/forums/tools-fab...available.html
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
lxcoupe
Jul 30, 2015 02:42 PM
Ketis
Jul 23, 2015 12:37 PM
black6spdz
Jul 16, 2015 01:32 AM
