stock metal fuel rails wtf?????
Old Jan 26, 2008 | 02:05 PM
jkwalkercchs's Avatar
harness for a regulaur gas motor im swapping this into a car
Old Jan 26, 2008 | 04:32 PM
Doobie's Avatar
Fuel rails on my 03' flex fuel engine are round plastic. Look just like standard rails. Never seen those type of metal rails before. Maybe for the early FF engines?
Old Jan 26, 2008 | 04:41 PM
silveradokidd_4518's Avatar
you should not have any problems with those fuel rails if you are gonna swap that engine into a car. the harness only plugs into the injectors. unless you are using a harness from a car then you will prob have to swap out the injectors
Old Jan 26, 2008 | 04:42 PM
grrrr wtf am i to do i can still see the part numbers on the rails where can i do a lookup
injectors should hook up the same tho right??
Old Jan 26, 2008 | 06:04 PM
Phantom's Avatar
11 Second Club
my truck is an '07 goober...i'd say they're the NEW FF rails...
Old Jan 26, 2008 | 06:24 PM
it came of an 04 thats the scary part
Old Jan 28, 2008 | 03:42 PM
joshluther's Avatar
The plug on the injector is different. I have a set of regular truck injectors and rails if you want to swap. The l76 setup I run uses those connectors and it would be nice to keep all of my motors the same. I do also have a set of car style injectors, I'm not sure what size they are though.
OHsixLS3
Dec 27, 2016 09:30 AM
jdb11386
Dec 3, 2015 09:34 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
