Stock LQ9 6.0L Oil Pressure at Idle?
Originally Posted by CHEVY6000VHO
So the oil pump Lingenflter sells is only a high volume pump?
Why is everyone telling me to change my oil pump out while I'm changing my cam out then? Do I need to change the oil pump that only has 30,000mi on it?
Here are my mods going in: Cam: 220/570/570/117lsa, Radix (3.0" pulley), Meth, & Dynatech Lt's.
So do you recommend using the same pump, new o.e. pump, or a different pump?
Jim
Jim
Originally Posted by Zick
I'm actually running the stock oil pump from my 5.3 but that shouldn't matter since they should be the same.
Originally Posted by litreddevil
i would not change the pump how many miles on the motor your talking about mine had issue with oil pressure and it turned out that the bearings were bad
JFWY
Mine dips to 25 @ idle, and 50 @ WOT. Doesn't go past that.
ARC
57
Feb 21, 2022 10:54 AM
Ferocity02
Jul 17, 2015 07:05 PM
GMCtrk
Jul 17, 2015 06:39 PM
