stock lifter preload
Old Aug 12, 2009 | 05:25 PM
03 BLACKOUTSSS's Avatar
Default stock lifter preload
Anyone know where I can find this info...searching yielded a lot of good info, just not this one little piece. If I can get this, I can mathematically figure out the proper PR length based on the amount of preload desired.
Any Ideas?
Old Aug 14, 2009 | 05:52 PM
no ideas huh?
Anyone think calling the dealership will get me anywhere?
Old Aug 14, 2009 | 11:20 PM
shandy294's Avatar
IDK,I thought you'd have gotten some replies.
Old Aug 14, 2009 | 11:29 PM
budhayes3's Avatar
PT's Slowest Truck
You could try calling the dealership, but I don't think that you'll get a straight answer. Maybe try PM'ing Zippy, he worked for a Chevy dealer for a long time, and is probably your best shot. If you have problems getting in touch with him here, try over at SilveradoSS.com, he's and admin there and on that site pretty much every day...
If you find out, post up your findings...now I'm curious to know myself
Old Aug 15, 2009 | 01:59 AM
ricoc's Avatar
Comp Cams say .030"
or you can just take a chance that someone on the internet said it was OK to just use the same length pushrods as they did
Old Aug 15, 2009 | 08:09 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by ricoc
Comp Cams say .030"
Hmmm...is that Comp's spec or the factory spec? That seems to be on the loose side of acceptable clearance.
From the research that 03 BLACKOUTSSS has been doing, I'm sure that he's attempting to do it the right way and not the "internet said so" route lol.
Old Aug 15, 2009 | 09:50 PM
ricoc's Avatar
that number is what I "remember" from doing my cam last year.
After squishing the lifter .030" from zero lash, my push rods had to be .070" shorter than stock. I assume my valves are worn that much. Still no bad sounds from the drive train. Pity GM didn't use adjustable rockers.
Old Aug 16, 2009 | 08:36 AM
Here are the factors that I can come up with for calculating the factory preload with an aftermarket setup...
Assuming the factory PRs are 7.380"
Factory PR preload - Zippy got back to me and said it was .050" - .090"
With that said, I am shooting for .070" preload
Variance in compressed Head Gasket Thickness - I have been told that the stock gaskets are .051" - .053". I installed a .041" gasket, which is a variance of .010" - .012", assuming .011" head gasket change
Lifter height - I installed LS7s which "reportedly" are .050" taller than the 2003 LQ9 lifters.
Given this info, and assuming the valve spring installed height is the same, lets do some math...
.070" preload with 7.380" PRs
change head gasket, preload goes to .081"
change lifters - Preload goes to .131"
Adjust PR length for .070 preload gives a .061" shorter PR.
7.380 minus .061" gets us to a 7.319" PR for .070" preload
7.325" PR gives us .076" preload
7.300" PR (whats installed now) produces .056" preload (on the loose side of acceptable range)
7.350" PR produces .096" preload - too much for my liking.
7.325" is the winner!!! (provided the spring installed height is the same as factory). That is the only variable.
Lesson learned - always get adjustable rocker arms.
5.3Okasai
Mar 9, 2022 01:07 PM
lxcoupe
Jul 30, 2015 02:42 PM
GM1697
Jul 20, 2015 08:41 AM
Suburban2500
Jul 19, 2015 04:50 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
