stock 6.0l injectors topped out?
Old Mar 9, 2009 | 02:17 AM
G-Body's Avatar
sawzall wielding director
Default stock 6.0l injectors topped out?
I`m confused here. I have a stock 2001 6.0L in my elcamino, the only mods are the air intake tract (4" pvc to a 4" K&N cone filter) and the exhaust is 2002 f-body manifolds through factory cats and a 2.25 x pipe with dual 40 series flowmasters. The injectors are from my 2001 5.3l so they should be the 24#/hr. I found that I was running 840mv (narrowband 02`s 98% injector duty cycle) at the top end of 3rd gear (5500rpm). Also found that my fuel pressure was dropping to 38psi.
I fixed the fuel issue and now have a constant 60psi. But I am still running out of injector. I am up to 917mv so maybe a little rich, but up there the injector duty cycle is 96-101% depending which WOT shot I look at.
Does it make sense that I`m running out of injector on a virtually stock LQ4??? Is there something else I should be checking?
Old Mar 9, 2009 | 09:20 AM
Old Buzzard's Avatar
Sent you a PM..
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
OLD BULL
Aug 1, 2015 05:00 PM
MS3Z
Jul 30, 2015 06:17 PM
