stock 5.3 heads
Old Jan 8, 2007 | 02:19 AM
blockheadnic's Avatar
10 Second Club
Default stock 5.3 heads
what is the biggest lift stock 5.3 heads will handle, not the springs but the actual heads them self.
Old Jan 8, 2007 | 08:35 AM
Richard@WCCH's Avatar
FormerVendor
If you installed a set of Patriot gold dual springs or something similar you could run .600" lift without problems. The retainer to seal clearance is over .700" so you've got plenty of room. With that kind of lift your next worry is the rocker arm...........
Richard
Old Jan 8, 2007 | 09:04 AM
Flyer's Avatar
WHat will stock rocker arms stand up to?
Old Jan 8, 2007 | 01:26 PM
10 Second Club
Well i was looking at around .581 lift. at the high end just wasnt sure if they had to get machined to fit that lift.
Old Jan 8, 2007 | 01:38 PM
FormerVendor
You'll be fine with that amount of lift. No special machining will need to be done.
Good luck,
Richard
Old Jan 8, 2007 | 02:59 PM
Rhino79's Avatar
9 Second Club
Yeah they aren't like the 96-98 Vortec heads were the retainer comes so close to the valve seal, I know guys running mid .600's on lift with no machining required.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
06 4.8
Jul 15, 2015 07:17 PM
