Sticky Lifter Help
Old Apr 1, 2008 | 09:58 PM
Southern Dixie Rebel's Avatar
Default Sticky Lifter Help
my trucks got a sticky lifter i think because it ticks and when i rev it gets faster so im pretty sure it is but how do u fix that cause its loud and sounds like crap thanks for yalls help
Old Apr 1, 2008 | 10:44 PM
cellulis44's Avatar
are you sure a lifters stiking?
Old Apr 1, 2008 | 10:57 PM
2002C5COUPE's Avatar
my rod bearings sounded like a tick too. i thought it was bad lifter at first
Old Apr 2, 2008 | 09:02 AM
SS_bnoon_SS's Avatar
First step is to get a mechanic's stethoscope to make sure it's a top end noise. If it is coming from the top side, it could be a lifter, a rocker, a bent pushrod... Just have to narrow it down.
If it does end up being a lifter, it's really easy to swap them out on the gen III/IV engines. You just remove the coil connections, then valve cover, loosen the rockers, pull the pushrods, then pull out the lifters and replace. Shouldn't take a novice more than an afternoon to swap out.
Old Apr 2, 2008 | 10:43 AM
budhayes3's Avatar
PT's Slowest Truck
I thought that the heads had to be removed to access the lifters
Old Apr 2, 2008 | 11:20 AM
aaronk227's Avatar
The head does have to come off. Check out LS1howto.com. The lifter retainers are below the heads.
Old Apr 3, 2008 | 04:46 PM
AGAMBILL's Avatar
Thanks for that link man, I couldnt find it to save me.
Old Apr 3, 2008 | 05:57 PM
brodystruck's Avatar
i was working on a 2003 chevy cavalier that had a sticky lifter. the recommended dosage of sea foam into the oil fixed it within about 3 seconds...
Old Apr 4, 2008 | 11:34 AM
AGAMBILL's Avatar
I have always heard that carbon buildup would cause a simular sound, dont know if theres any real truth to that.
Old Apr 4, 2008 | 11:47 AM
OK, minor details, DOH!!!
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
chvy=power
Sep 8, 2015 11:06 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
