Steering shaft hitting Pacesetter headers
Old Jun 16, 2006 | 11:19 AM
agreif's Avatar
Default Steering shaft hitting Pacesetter headers
Anyone else have this problem. Did a search and got a lot of these problems when it came to Thorleys. Here's a pic. First plan was to dremel the end of the bolt off with the backup plan to moving the steering box and getting an alignment. Thoughts?
Old Jun 16, 2006 | 11:22 AM
black4.8's Avatar
is it just the bolt hitting? can you flip the bolt around or put a shorter one in?
Old Jun 16, 2006 | 12:12 PM
agreif's Avatar
I think flipping it would get be to the same spot (that head looks kinda thick), I think the shorter is the way to go (ie Dremel).
Old Jun 16, 2006 | 12:29 PM
LesPaul's Avatar
thats fucked up man... mine were like 6" from the header
Old Jun 16, 2006 | 01:44 PM
Beastofa327's Avatar
Mine were fine gettin past the shaft and aren't hitting when I turn the only problem I had putting the in was the trans and the trans lines had to remove the trans support and move the trans and engine over about 2" on mounts to fit between the frame.
Old Jun 16, 2006 | 02:10 PM
agreif's Avatar
Wonder if it's just a matter of where you steering box is set up from the factory.
Old Jun 16, 2006 | 02:31 PM
Nick™'s Avatar
do you know for a fact that the truck has never been wrecked? clearance is tight, a slightly bent frame will cause interferance
Old Jun 16, 2006 | 02:35 PM
shandy294's Avatar
Cut-off wheel or shorter bolt (maybe loc-tite it) like you were saying.
Old Jun 16, 2006 | 03:51 PM
Zick's Avatar
Break out the sawsall.
Old Jun 16, 2006 | 08:16 PM
black4.8's Avatar
take the good ol' dremel to it.
