starting...or not
Old Dec 20, 2008 | 05:34 PM
joeyc125's Avatar
11 Second Truck Club
well replaced the battery cable and problem is solved... only to create a new one. It is now running like crap, bank 1 trims are way rich and bank 2 are way lean, lt's are at 25 and st's are around 10-15 on top of that. what could that be? i checked my plug wires, exhaust leaks, can't find any intake leaks? thinking something could have gone funky in the pcm with all this electrical problems?
Old Dec 20, 2008 | 05:45 PM
GMCtrk's Avatar
did you check all your grounds?
Old Dec 20, 2008 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
The PCM may need an idle re-learn from the battery being dis-connected. There's a procedure for it, but I've found that driving the truck around and beating on it a little bit usually allows the PCM to relearn itself. If that doesn't work I'd start with typical diagnosis (visual inspection, grounds, check spark, fuel, etc.)
