4.8 pistons in 5.3
Old Dec 1, 2008 | 04:17 PM
sdimer350's Avatar
Question 4.8 pistons in 5.3
toying with the idea of putting 4.8 pistons(flat-tops) in a 5.3. what kinda comp would this net me with stock heads and gaskets? if its over 11-1 i wont do it. i got a 4.8 and a 5.3 crank and rods layin around that need to be put to use. come on you compression calculating gurus!
Old Dec 1, 2008 | 06:50 PM
sdimer350's Avatar
anyone anyone
Old Dec 1, 2008 | 07:09 PM
kbracing96's Avatar
Not sure on the comp, but its been talked about like 30 times. A search will keep you reading for hours
Old Dec 2, 2008 | 12:02 PM
sdimer350's Avatar
according to the cr calculator, with a stock gasket(.053 thick) and 0 deck hight to be safe it only come to 10.3-1 sounds kinda low to me but maybe not. what do you guys think?
Old Dec 2, 2008 | 12:14 PM
xx_ED_xx's Avatar
I am guessing the compression height of both pistons are the same?
Old Dec 11, 2008 | 09:00 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
4.8L = flat top pistons
5.3L = dished pistons
Saw an article on this recently, but I don't think there were numbers to show what the numbers would be. Looking...
Old Dec 11, 2008 | 09:21 PM
lo&sloSierra's Avatar
Old Dec 20, 2008 | 11:37 PM
RADO_4U2NV's Avatar
It can be done, the only diff in the two is the stroke. Bore is the same. Have you tried the search button? May find the thread 1BADC10 is talking about.
ferrellrooster
Mar 6, 2025 03:22 PM
lycominghunter
Aug 15, 2015 12:26 PM
JordanH
Aug 8, 2015 07:59 PM
06 4.8
Jul 15, 2015 07:17 PM
kdw8888
Jul 9, 2015 10:52 PM
