starting boat LQ4 6.0 conversion.
Old Oct 12, 2011 | 02:41 AM
Default starting boat LQ4 6.0 conversion.
My bro and I have had boat fever for a while and we picked up a cherry 20 ft ski boat with a popped 350. I have a spare 6.0 and got to kicking around dropping it in with a mild cam and a set of 243 heads.
Or maybe 243's and LS6 cam to save some cash have both already laying around.
It will be run in fresh water only anyone care to guess on estimated life of aluminum heads used in this manner? Used often and drain the block during winter storage is my plan.
For exhaust I'm thinking a set of LT's off my old 6.0 sierra should do the trick
I can modify a pcm harness myself to do what I'm needing.
Pretty sure a 4l80e crank spacer can be used with whatever SBC flywheel assembly is in the boat currently.
Use truck intake and front accessory drive setup.
It's in the planning stages now we just got home with it after a 4 hour road trip trying to figure out how to shove LS power into the beast.
Ideas or thoughts
Old Oct 12, 2011 | 06:00 AM
Tootall's Avatar
There's a few on tech that have been done... compressor serge I think...
Old Oct 12, 2011 | 07:44 AM
lt1s10's Avatar
You are going to want to use water jacketed manifolds unless your engine compartment is completely open. I know some have used old sbf exhaust manis and stretched the bolt holes out. You are also going to need a way to distribute the water from the raw water pump... Staying efi or going carb?
Old Oct 12, 2011 | 10:02 AM
walledition's Avatar
we just installed a 2004 z06 engine in a boat, actually the mechanic fired it up last week, just need to fix some final bugs and we will hit the water, i´ll post pictures and videos once we finish it all
good luck with your project
Old Oct 12, 2011 | 10:59 AM
89LS1FOXER's Avatar
been wanting to do this also, lets get some pics!
Old Oct 12, 2011 | 07:40 PM
thanks
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
davis28905
Jul 8, 2015 03:20 AM
