stand alone fuel for nos-done for now
Old Sep 9, 2004 | 05:54 PM
one03sierra's Avatar
Formerly one92rs
Talking stand alone fuel for nos-done for now
ok i finally got this thing working like i want it to. i still need to make some brackets for the hoses under the truck. and i am going to run another rubber line for the feed maybe. first off is the fuel cell-summit-sum 290122. it is a JAZ fuel cell with foam in it. one 6an return-one 6an vent-two 8an outlets. or #6 and #8 jic will work. i mounted the tank with 1/8X1" aluminum straps from lowes hardware.i was told to mount it up so the pump will be inline with the sump.i capped off one of the outlets as i did not need it.
the regulater. i bought the summit kit since that is what i thought would be the best. i think that it can be done cheaper and maybe better. i tyhink a holly blue pump and reg will work. the kit did come with the filter and all. the reg was a dead head style reg. it did not dump back to tank. so when i pressured it up it would climb to 15 psi and bog some. so i had to get a barry grant bypass reg. there are a lot of others out there. nos and aeromotive make nice ones also. i bought mine from a local speed shop.
the rest is the kit from summit. filter and pump.i put a relay on the solenoids and heater in the back. i am getting a fitting soon that will allow me to put in a switch for the fuel. it will shut everything down if it drops below 5 psi.
Old Sep 9, 2004 | 06:08 PM
Sweet complicated set-up. lol
It looks like your going to start spraying some serious HP into that thing. How big of a shot are you planning?
Old Sep 9, 2004 | 06:31 PM
BigBlockChev572's Avatar
Yeah, it is nice looking set up! It's so purty! Yeah, so what shot?
Philip S.
Old Sep 9, 2004 | 06:41 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
If you have an adequate fuel system, how big of a shot can you spray before something gives, like a piston or whatever? 175?
Old Sep 9, 2004 | 08:37 PM
Well i know a 225 shot aint **** for our motors. So my guess is with adiquate fuel and tuning a 300 shot isnt out of the question.
Old Sep 9, 2004 | 11:28 PM
Formerly one92rs
Talking
ok i tied all kinds of pressure settings. could not get it to run right to save my life. i did talk to someone and got some info on how i need to fix some things. i need to get my solenoid repaired and go back to old set up for now. i think i might even remove all this and sell it. ill keep you posted up.
Old Sep 10, 2004 | 08:56 AM
tooquick2beslo's Avatar
you sprayed a 225 dry shot on a stock fuel pump and stock injectors ?????
Old Sep 10, 2004 | 04:12 PM
A 225 shot and those mods are only good for high 12s?
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
davis28905
Jul 8, 2015 03:20 AM
Nimoryan
Jul 5, 2015 03:50 PM
