stall or 4.10s
Old Nov 23, 2005 | 08:28 AM
Default stall or 4.10s
well i have about $1000 i was wondering if i should go with the yank 3000 or 4.10's for a better time at the track. this is my everyday driver but im not to worried about the gas mileage. these 3.42's are killin me
Old Nov 23, 2005 | 09:06 AM
TurboGibbs's Avatar
$1000 = stall and gears
but if just one, I'd say stall.
Old Nov 23, 2005 | 09:13 AM
do you have to tune for 4.10s??
Old Nov 23, 2005 | 09:35 AM
Bad_Apple's Avatar
I put the Yank 3000 stall.... You'll be kickin your self wondering why you already have not already installed a stall. I believe it will work nicely on the street with 3:42's
Old Nov 23, 2005 | 10:10 AM
ap2002's Avatar
$1000... hummm.... maybe a stall and a custom tune!!!
Old Nov 23, 2005 | 10:12 AM
1SlowHoe's Avatar
Destroyer of Transmissions
I say gears because it won’t affect your towing capacity. The stall, unless specified for towing, will limit your tow capacity and raise tranny temps. Yes you have to tune for gears. Shift points and your speedometer will be off. But for $1000 you could almost get an Eaton, gears, and a stall if you do the work yourself. Save a couple hundred more and do both. Then a tune adjustment can be done with a Predator or another hand held if you dont want to go for an all out tuned pcm. Then again, some tuners will do a whole tune for under $200. It never ends.
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
bisqikss
Sep 27, 2015 09:40 PM
