Stainless Works headers Install
11 Second Hall Moniter
You won't need a new dipstick or tube unless you manage to break yours.
Removing it is easy.
Remove the dipstick from the tube.
Remove the single bolt holding it to the head, save the bolt.
Pull and twist the tube, back & forth, straight up out of the block.
Clean up the tube & inspect the o-ring. Replace o-ring if needed.
You may need to grind/trim the tab to clear the header flange.
After you have the passenger header on, you can reinstall the tube.
Lubricate the o-ring with assembly lube or clean engine oil.
Use a small flashlight to help see the hole in the block.
Twist back & forth as you push down & seat the tube.
Bolt tab to cylinder head.
I would reuse the stock ones. The GM gaskets are much better. 18 foot pounds I think. I would do two passes. First like 10 or so starting from the middle and working out.
FlowmasterMufflers
07-17-2015 03:26 PM
FlowmasterMufflers
07-09-2015 12:00 PM
