srt nothing! drove to the track, ran a 10 drove home, no nitrous.
Old Mar 27, 2005 | 12:49 PM
  #41
parish8's Avatar
single digit dreamer
Originally Posted by Flyer
I thin you have a LOT to gain with some good heads. If it were me, I would be looking at a nice set of AFR 225's.
i could make that my next mod, seems like heads are often near the bottom of FI guys list. maybei will post up in the FI section and see what they think.
Old Mar 27, 2005 | 12:54 PM
  #42
Faze2183's Avatar
Originally Posted by Chingon
Are you sure?
Good run Parish!
thats funnnnnny
Old Mar 27, 2005 | 01:03 PM
  #43
I think the AFR heads with the thicker deck would let run higher boost without lifting the heads.But I doubt you'll see a big horsepower increase.I'd look into better turbo housings first.
Old Mar 27, 2005 | 01:16 PM
  #44
zippy's Avatar
sounds like a larger turbo may be more gain than heads. congrats on 10's without nitrous jim.
Old Mar 27, 2005 | 02:08 PM
  #45
hellbents10's Avatar
LS1Tech Sponsor
Good job.
Like I said before the t-76 is not a turbo for a all out 408. You are right out of the efficientcy range the way I see it. Hence your high IAT's. Have you improved your hot side yet too. Rather then fight tooth and nail it would be easier to upgrade the turbo and the hot side. You could go low 10's on boost then.
Old Mar 27, 2005 | 02:21 PM
  #46
parish8's Avatar
hotside is looking prety good these days. that is 3 people sugesting a larger turbo and after looking at the maps i have to agree.
look at this map or the 76 and line up 90lb's and 2.1bar.... not so good, about 50%
now look at the 88 map, 90lb's an 2.1 bar... oh yeah, 78%
now i need to go find some calculator for that and see how much hp that might be and that is without even looking at turning it up wich i can't do with the 76.
Old Mar 27, 2005 | 02:36 PM
  #47
parish8's Avatar
the calculators sugest about 50hp if i dont turn up the boost at all, then room to crank it up another 200+hp on top of that and still be at 70% or better. that t88 sure has a nice map.
Old Mar 27, 2005 | 03:28 PM
  #48
Black Blown 02's Avatar
Will an 88 fit with just a flange change?
Old Mar 27, 2005 | 03:30 PM
  #49
parish8's Avatar
no, i would be a little more work than that.
Old Mar 27, 2005 | 04:05 PM
  #50
Parish,why not go with a bigger intercooler reservoir like the Vortech unit that Big Tex is running to make icing the intercooler easy.It's basicly a small fuel cell so the opening is large enough to pour ice into,just pickup a cheap flush valve to drain the hot water from your heat exchanger pour ice water into the reservoir and circulate it with the electric water pump until the mixture is near freezing,then stage.It's not a hightech mod,but would drop air temps by probably 20 to 30 degrees,for about $200.
