Spun bearing after procharger install
Old Apr 2, 2015 | 07:56 PM
Byrdman11's Avatar
Pull pan and head install piston. Install a nice meth kit too.
Old Apr 2, 2015 | 08:17 PM
George C....'s Avatar
Formerly ScreamingL
called that ****, black bear starter tune....shouldnt of been beating on it
sorry to hear
Old Apr 2, 2015 | 08:49 PM
Delaware ss's Avatar
1/2 throttle is beating on it? It never went past 4500 rpm
Old Apr 2, 2015 | 09:35 PM
quicksilverado's Avatar
Does not matter if it was not tuned for it. In your original post you said you went 3/4 throttle and saw 8 psi. That is more than enough to hurt the engine without a proper tune.
Old Apr 2, 2015 | 10:17 PM
gonzo 6.2's Avatar
YIKES you had no tune? I read it wrong thinking you had a BB base boost tune
Old Apr 2, 2015 | 10:46 PM
GMCtrk's Avatar
Originally Posted by sierra416
Had the same thing happen to me when I installed my turbo. Checked everything. Couldn't find the problem. Tore apart block and found 7 of 8 rods bent. Those powder metal rods are junk. Never went over 4psi. Now it's honed and forged 416ci. Good luck with yours. Hopefully it's something inexpensive.
Piston slap - not my pic but this is what my rods looked like.
The rods are well documented to hold at least 700 rwhp. In fact, I'm still running on a stock bottom end for about 2.5 years boosted and many people make much more than me and go faster. Sounds to me like you had a bunk tune.
Tune and fuel are critical when it comes to boosted motors.
Old Apr 3, 2015 | 02:13 AM
Formerly ScreamingL
dude my blower sees 9 psi by that rpm even part throttle
cant blame anyone but yourself
Old Apr 3, 2015 | 02:15 AM
Formerly ScreamingL
strong rod motor in our Notch....25psi+20* timing+ e85 +11.4afr+ 7300rpms thru traps
164mph@3400lbs
unless its a weak rod then stick around 750rwhp max for saftey
Old Apr 3, 2015 | 03:41 PM
Not blaming anyone, things happen with mods I understand that completely...
Just wanna know what's wrong and why so it doesn't happen again when I rebuild it. If it was just the tune that's fine I can live with that I had an appointment for a dyno tune and yes I probably should of just waited to drive it until after that I use see a lot of people using the bb tune and it working fine. I do lap percolate all the input. I'm pulling the head next week so I will see then how much I gotta do to fix it.
Old Apr 3, 2015 | 03:51 PM
Before and after video
