Speed Engineering Twin Turbo Kits!!
Old May 21, 2018 | 09:31 AM
  #81
Speed Engineering's Avatar
Former Vendor
Last we heard is we should be receiving most the missing items of the kit within the next 3-4 weeks. Fingers crossed.
Thanks
Sean
Old Jun 9, 2018 | 10:56 AM
  #82
That sucks about the supplier issues. Kit looks promising, hope your supplier can come through and KEEP you stocked. Very interesting....
Old Jun 12, 2018 | 09:32 AM
  #83
Former Vendor
I think we will be ok keeping enough inventory. It's just getting it dialed in the first place that seems to be the issue. Both hot and cold sides are good now. The last issue we're having is the AN fittings/heat shields supplier. Looks like we might need to change factories for those now. Waiting on a response from them. Hopefully this does not delay our kits too much longer.
Thanks
Sean
Old Jul 6, 2018 | 10:16 AM
  #84
MrHorsepowerLSx's Avatar
11 Second Club
Bumping this for updates
Old Jul 6, 2018 | 03:50 PM
  #85
Nwfjarhead's Avatar
Starting to wonder if it’s ever going to happen.....
Old Jul 9, 2018 | 01:42 PM
  #86
Former Vendor
We actually just got word last week that our cold sides are done, and will finally be coming in approx 3-4 weeks. Our hot side just showed up last week. I believe all we have left are the AN fittings, and heat shields, which shouldn't be far behind.
Thanks
Sean
Old Jul 9, 2018 | 07:32 PM
  #87
Dnick0958's Avatar
Registered User
Default Fuel system
Other than tune and bigger injectors what needs to be changed with the fuel system? A bigger fuel pump needed as well?
Old Jul 10, 2018 | 03:03 PM
  #88
Yes, or 2 pumps. And a boost referenced fuel pressure regulator.
Old Jul 11, 2018 | 12:55 PM
  #89
Former Vendor
Fuel system would depend on your HP goals, and fuel type. But, yes those are the only thing not offered with our kits.
Thanks
Sean
Old Jul 11, 2018 | 02:34 PM
  #90
Dnick0958's Avatar
Registered User
Default Fuel system
Thanks
Sean
i have a 2011 Silverado with 4.8 and 4wd I’d say 400-450 rwhp range probably would be the goal. If I bought the kit what would you say I’d need to pair with it (fuel system wise) to support those numbers ?
