specs on stock 5.3 and 8.1 fuel sys
Old Jun 23, 2005 | 04:40 PM
02sierraz71_5.3's Avatar
Default specs on stock 5.3 and 8.1 fuel sys
Will a stock 5.3 fuel pump be able to feed 8.1L injectors sufficently?
What is the stock pump rated at for a 5.3 and 8.1L, differences?
5.3 fuel rail pressure?
8.1L injector rated fuel pressure and flow rate?
thanks
Old Jun 23, 2005 | 09:02 PM
anyone know these specs or where I can find them?
Old Jun 23, 2005 | 09:35 PM
litreddevil's Avatar
Banned
What Specs Are You Looking For
I Know That Just @ The Beginning Of The Week And 8.1 Was Around 50 Lbs
My 5.3 Is At 64 Lbs. I Don't See Any Problem I Am Thinking Of The Same Thing For A 408 Are Something In That Neighborhood
Old Jun 23, 2005 | 09:49 PM
MrXerox's Avatar
I have a set of non-marine 8.1 injectors for my 5.3 as well. Hopefully someone has these already installed and can tell us these answers so I can install mine too
Old Jun 23, 2005 | 10:24 PM
TieRod's Avatar
8.1 truck 31lbs, marine 8.1 43lbs. Both the 5.3 and 8.1 injectors are rated for the same presser. The 5.3 pump will be fine unless you are using 8.1 marine injectors close to their max. Then you'll need a pump booster. I don't know what flow the pumps are rated for but I do know they're different.
Old Jun 23, 2005 | 10:35 PM
thats good info tie
thanks
Old Jun 23, 2005 | 11:21 PM
MrXerox's Avatar
Anyone have the proper values to scale the injector tables in a 5.3 with the non-marine 8.1s installed?
Old Jun 24, 2005 | 01:18 AM
found this over on hp tuners website, figure its worth a shot sounds very reasonable and easy
edgZ06:"click engine-general fuel- flow rate vs kpa. Your staock or current fuel injector size is listed.
If your stock injectors are 29 #, then at 0 vacuum the number shown is 29.15. If you are upgrading to 60 # injectors, just subtract 29 from 60 and add that number (31) to all the cells and that will do it."
Heres a calibration spreadsheet from redhardsupra one is for inj pw and the other for duty cycle
File Type: zip
File Type: zip
Old Jun 24, 2005 | 01:27 AM
another method from
chris(owner of hp tuner)
the easiest way to tune for larger injectors is to know the ratio of your existing ones and the new ones. eg. if your current ones are 28lb and new ones are 36lb then mutliply your whole table by 36/28 or 1.286. Its not exact but gets most of us close enough.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
NuckenFuts
Jul 9, 2015 08:45 AM
