Spark plug selection?
Old Jul 23, 2013 | 11:48 AM
marineusmc4's Avatar
Default Spark plug selection?
Im gonna be changing the spark plugs and wires, along with oil change tonight before i have my truck retuned tomorrow. I know this seems simple but what type of spark plugs should i use? I have heard to use oem, ive heard use platinum or iridium, etc. truck and mods are in signature. Same question for the spark plug wires, oem or aftermarket? Oil is Mobil 1 full synthetic 15w-50. thanks in advance.
Old Jul 23, 2013 | 12:41 PM
WhiteX's Avatar
Why such a heavy oil?
And there are a million opinions on spark plugs. I prefer Autolite XP iridiums.
For plug wires, OEM is fine. They also likely don't need to be replaced unless they have a TON of miles on them.
Old Jul 23, 2013 | 02:06 PM
I just picked up some AC Delco Iridium Professional, like 6.99 each, and some AC Delco OEM wires. My truck has 160k on it, original wires, and about 70k on the current spark plugs. I just did a cam swap not even two weeks ago and did an oil change at the same time as the swap, using 5w20. I had heard to use a thicker oil so im doing another oil change tonight to get rid of that cam "break in" oil. I dont think that the oil will hurt it til the winter time when it takes longer to heat up.
Old Jul 23, 2013 | 02:19 PM
Ferocity02's Avatar
Oil thickness should depend on your bearing clearances and/or oil pressure. If your oil pressure is good with a 30 weight then you shouldn't run anything heavier. 20 weight is probably too thin. I'd use a 30 weight, or 40 in a high heat application like with a turbo. In short, I would definitely not run a 50 weight.
As for plugs I would run TR55's, they are cheap, work well, and last awhile.
Old Jul 23, 2013 | 02:28 PM
Im in Kansas City and it has been around 95-100 degrees out so thats why i was thinking the 50 weight might be a good idea, but i can always return the oil and get some 30 weight if ya'll think that its a better idea
Old Jul 23, 2013 | 02:34 PM
Ferocity02's Avatar
What's your oil pressure with the 20 weight?
Old Jul 23, 2013 | 02:49 PM
at idle its right at 40psi plus or minus a few with rpm flucuation
Old Jul 23, 2013 | 02:52 PM
so what do u think i should get, 5w30 or 10w30?
Old Jul 23, 2013 | 03:01 PM
Kemble's Avatar
NGK V power plugs. Pennzoil platinum 5w30 and a wix filter. At least thats my preference.
Ferocity02's Avatar
If it were me, I'd do 10W-30 in the summer, and 5W-30 in the winter. That's a good oil pressure for 20 weight. 30 weight will net you a little more. 50 weight would be way too thick.
