Something wrong with the way it shifts
Old Sep 7, 2007 | 09:41 AM
Biggin's Avatar
Default Something wrong with the way it shifts
In my 03 chevy truck I had to get the transmission rebuilt and it shifts fine if you leave it in drive. But if you shift it your self it will hang up in secound if you hold the gear out to long. But then if you trun the truck off it will drive rite.
Old Sep 11, 2007 | 09:47 AM
Biggin's Avatar
can somebody help me with this.
Old Sep 11, 2007 | 11:36 AM
butch 02 denali's Avatar
Really hard to diagnose this without some more details. I have seen similar problems when a shift kit was added along with a pcm tune that had raised the tranny line pressure, and/or shortened the shift times, and or the addition of Vette or Billit servo. The combination of the parts and the shortened shift times can cause a shift overlap preventing the tranny from shifting.
I'd start with a line pressure check.
Old Sep 12, 2007 | 09:28 AM
Biggin's Avatar
Well when i had the tranny rebuilt they told me they were having trouble gettin the line pressure rite the told me that my computer was messed up because in efans pulged into it.
Old Sep 12, 2007 | 11:23 AM
E-fans have nothing to do with PCM tranny or engine functions. The IAT sensor in the maf does though.
This needs to be checked with a scanner. You need to know if the pcm is sending a shift command or not when it's hanging up. If the shift command is sent but the tranny doesn't shift, then it's either too much line pressure, a shift timing overlap, or a sticking solenoid. If the shift command is not sent, then it's your pcm.
Who did your tune?
Old Sep 12, 2007 | 11:25 AM
Tootall's Avatar
having fans "plugged in" will not change anything. Now if you have a your computer tuned, and if the tuner bumped the line pressure up, with a shift kit, . . . then you might be having problems.
Do you have a custom tune, or a shift kit?
Old Sep 13, 2007 | 09:46 AM
Biggin's Avatar
Im fixn 2 get a tune will they be able to if the line pressure is out of wak
jtphelps289
Sep 29, 2015 12:00 PM
01silvy
Sep 26, 2015 10:20 PM
fortune46x
Sep 16, 2015 08:18 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
