Some random 5.3 questions
Old Nov 3, 2009 | 04:48 AM
Gutling's Avatar
Default Some random 5.3 questions
I am working on swapping this 5.3 into my s10 and had a few questions. It is a 06 out of a silverado.
I toke off the dbw t/b and going to run a cable t/b, but what are yall doing for the throttle cable/cruise cable brackets? Is there a part number for what I need or does someone have it on here? There is nothing on the side of the manifold to hold them.
Has any one plugged this up where the evap went? What did you use?
Are these flex fuel injectors or regular?
Thanks for the help, and I am sure I may have another question or so soon.
Old Nov 7, 2009 | 04:27 PM
Low91's Avatar
This should be the part number for the bracket 15709993. It bolts to the top of the manifod to three of the brass inserts. All I did to plug the egr hole(or whatever that useless part was) was to dip a bolt in some epoxy then shove it in there.
The best place to find answers about a swap like your doing is www.ls1truck.com if they can't answer your questions then no one can.
Old Nov 9, 2009 | 08:14 AM
reiners88's Avatar
yea im thinking about doing a similar install on my S10. post some pics when you start the swap.
Old Nov 10, 2009 | 08:32 AM
Gutling's Avatar
Thanks, I actually found a egr plate blockoff from a lt1 that blocked the evap hole perfect. And going to call gm and get that part number coming, I appreciate it.
Three6GMC
Aug 3, 2015 07:53 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
03sierraslt
Jul 11, 2015 02:47 PM
