some cam advice
Old Nov 1, 2004 | 08:51 PM
Mangled03gmc's Avatar
Baltimore Whore
so what would the most amount of lift be that i could run and still not be a bitch to tune.560/more.should i go with a traditional split reverse.i'm not talkin about having a custom grind just a good off the shelf cam. btw thanks for this info
Old Nov 1, 2004 | 08:55 PM
one03sierra's Avatar
Formerly one92rs
Talking
lingerfelter gt2 cam. off the shelf.
Old Nov 1, 2004 | 09:07 PM
Baltimore Whore
thanks i will check it out.
Old Nov 2, 2004 | 05:08 AM
Sport Side's Avatar
Originally Posted by 02denali
damn. now that is good. yay throw in a 112 lsa and retard it.
just by the right cam and stick it in and it will be right. with a 112 lsa there is overlap and it is causing a vaccumn type motion. uuuhhh doh. we are going to be forcing it in there. so we dont need that. we need the valves to be closing so as to not bleed off boost.
Denali,
You need to realize, it depends upon the type of blower also. Take a procharger for example. They create boost in the upper rpm range.
Throwing in a camshaft with alot of duration and a wide lsa, is going to....maximize top end power.
why, would you do that when you induction is forced at those rpms.
Small duration, small standard split. Tight lsa, to help bottom end performance. Something like that would have very little overlap.
You need to work with the rpm operating range. To much duration will throw you over this.
Take the stock camshaft. Its run on a 114 lsa. On a 112, it wouldn't have a shitload of overlap. There would be nothing wrong with retarding a camshaft. Many are ground with 1-2 degrees retarded for naturally aspirated setups.
Do you know how to calculate overlap? In the formula, more duration has an effect on overlap. You can calculate the degrees of overlap. (in., duration + ex., duration / 2 - (2 * lsa)
Give me the lingenfelter gt-2 camshaft specs @ .050 w/ the icl, if you don't mind.
What? are you talking about lobe profiles?
Old Nov 2, 2004 | 05:44 AM
Sport Side's Avatar
I get where your coming from.
Bleeding off boost can occur with excessive overlap.
The thread starter, hasn't named the type of blower, operating range, or really anything. So we're stuck on disagreements about the lsa
I'll just clear one thing up. I wasn't pointing out that a 112 is the best for boost. But given low overlap, optimizing low rpm isn't a bad thing. And I don't disagree with wider lsa's.
Check the FI section. Many are using 115lsa's. But they're camshaft has 232* of duration @ .050. fairly big for a motor of our size. again, depends on the rpm range. and so on.
thats all , no hard feelings
Old Nov 2, 2004 | 06:53 AM
Formerly one92rs
Talking
i do realize it all. with a 112 lsa it will bleed boost. with a 114 to 115 lsa it will bleed less boost thus making more power. period.
Old Nov 2, 2004 | 07:15 AM
Deckhand's Avatar
yea, i agree.
Old Nov 2, 2004 | 07:45 AM
Formerly one92rs
Talking
radix will suggest a gt2 cam which is--207/220/573/580-118.5
Old Nov 2, 2004 | 09:47 AM
marc_w's Avatar
I'd like to use VHP's "Trucker" for a FI setup.
216/224 .550/.550 115.
Funny thing is, it has 1* more overlap than my little guy... and mine's on a 112. I wonder how well mine would work?
Old Nov 2, 2004 | 01:00 PM
Sport Side's Avatar
I don't understand the way you use the phrase "bleed boost"
Would you mind explaining?
