some cam advice
Old Nov 2, 2004 | 01:04 PM
  #21
Sport Side's Avatar
207/220/573/580-118.5
Would you mind listing the ICL? I'll assume its straight up for the time being.
Old Nov 2, 2004 | 01:33 PM
  #22
Originally Posted by SportSide 5.3
Snake Eater,
Where am I wrong?
I said, MY THOUGHTS were,
-exhaust biased camshaft
-never mentioned lift
-never mentioned *'s of duration, nor *'s overlap
-A 112lsa, or of that nature. Give or take.
Pull in more area under the curve, with a tighter lobe seperation angle, BUT maintain minimal overlap. Yep, its possible. Retard the camshaft a few degrees, keeps valve events same, but held open longer. Thats an option.
and what the **** is good overlap?
I was refering to the 112LSA. Its tried and true you need a higher LSA. One of the reason a lower LSA cam gives you more low end is the timing you can throw at them. The nice lope comes from the intake valve AND the exhaust valve being open at the same time. Which would let boost (not all but some) bleed right out as fast as it goes in. To get good low end you need fairly small duration, low LSA, and lots of timing.
Lots of timing + boost =
Old Nov 2, 2004 | 01:51 PM
  #23
Sport Side's Avatar
You need a wider lobe seperation than what? Saying the lobe seperation angle must be inbetween a numerical amount of degrees is B.S.
The setup will tell you what it wants. I can give examples.
Their are setups that call for 106 lsa's. If a guy adds, boost he doesn't automatically need a 114, 116, or a 118lsa. It knocks the power band way out of proportion.
Old Nov 2, 2004 | 01:56 PM
  #24
Sport Side's Avatar
i do realize it all. with a 112 lsa it will bleed boost. with a 114 to 115 lsa it will bleed less boost thus making more power. period.
Denali,
Your looking at this all wrong.
The lsa is a by-product.
The choosing of the valve events will play the role in the amount of power is made. PERIOD.
Old Nov 2, 2004 | 02:21 PM
  #25
OK, where's BigTex?
ALL fuel injected applications with hydraulic roller cams use higher LSA cams.
ALL carbed applications with solid roller cams use lower LSA cams. A 108 LSA cam in an old carbed 350 isnt all that radical, but a 108 in a FI engine it will hardly idle and lope like crazy.
LSA is a huge factor in valve events and powerr band. Yes a 112 will make more power low and mid than a simular 114, but with a 112 leaking more boost out than a 114, and the fact that the timing CAN NOT be too agressive in a boosted application the 114 will make more power.
Old Nov 2, 2004 | 02:29 PM
  #26
Sport Side's Avatar
its about where you place the overlap, the timing of the valves. You need to watch that video of the Aussie GOAT, with 242* of duration on a 106. It idles better than that LPE camshaft your loping. Different setups, yes. Same concept.
Ok, look at it this way.
If you throw a wide lobe seperation at it. It effects the valve events. This may cause a loss in power. It depends upon the setup and what it calls for.
Old Nov 2, 2004 | 03:08 PM
  #27
one03sierra's Avatar
Formerly one92rs
Talking
boosted set up's need a wide lsa. period. i guess you need to call magnacharger and lingerfelter and tell them they are full of **** and you are a genious.
Old Nov 2, 2004 | 03:24 PM
  #28
Sport Side's Avatar
Here's a quote for you...
The last Pro Charged 370CID SB Ford engine I cammed made 1632HP at 8400 rpm. LSA was 113. There is no reason for a 118 lobe sep.
Chris
Yeah I'm a baby and went crying for some back up. But, your ignorance was pissing me off and he gave me his thoughts.
Old Nov 2, 2004 | 03:38 PM
  #29
Formerly one92rs
Talking
uh thats not fuel injected--we dont spin to 8400 rpm;s --and we damn sure arent fords.
Old Nov 2, 2004 | 03:48 PM
  #30
Sport Side's Avatar
and your point?
i thought all boosted applications needed a 114-119lsa?
at least thats what snake eater was saying. you didn't disagree, so i'd have to assume you thought so as well.
