So, peep this...
Old Feb 22, 2015 | 10:52 AM
texasglock23's Avatar
Default So, peep this...
cam bearings look worn, but online, many folks said the copper is normal, the second from the front bearing has some grroving, as does that support lobe.
thoughts?
Old Feb 22, 2015 | 12:56 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Those look a little more worn than normal.
I would replace.
Is that the stock cam? are you doing a cam swap?
If that specific cam is going back into the motor I would send it to a cam grinder to have it checked for straightness and the journals polished.
Old Feb 22, 2015 | 01:03 PM
It is stock. Dod lifter failure. Yes I am reusing it, as a lamp! I have a pat g spec'd 222/226 going in.
Old Feb 23, 2015 | 05:12 PM
Well, motor is being pulled and disassembled. Not sure how far I'll go, but at minimum I'll do all new bearings, polish crank and arp goodies.
Old Feb 27, 2015 | 10:25 AM
ScottyBoy's Avatar
What other mods are you throwing at it beside the cam and ported heads?
Old Feb 27, 2015 | 06:11 PM
Not 100% sure. May go forged. Doubt I'll stroke. Trying to stay on a reasonable budget.
Old Feb 27, 2015 | 07:35 PM
settlemoore's Avatar
Yikes...Sorry about your luck jayrod. Hope the bad streak ends here lol
Old Feb 28, 2015 | 12:12 AM
iamkeniff's Avatar
Looks about like mine did. Just forged it with arp everything and never looked back
Old Feb 28, 2015 | 12:33 AM
GMCtrk's Avatar
that looks similar to how mine appeared. Buttoned it back up and kept truckin.
Old Feb 28, 2015 | 03:21 PM
Some have stated they did the same, but I have horrible luck. I am doing forged pistons. Brian Tooley said I'd be fine with rods and crank since I'm not looking for big numbers, plus I'll do some spray later on.
InsaneDomestics
Jul 27, 2015 02:42 PM
Hit Man X
19
Jul 12, 2004 11:59 PM
Hit Man X
14
Apr 10, 2004 10:12 AM
crazyidiot4.8
Mar 20, 2002 07:33 AM
