So my LPP Y-pipe showed up today, WOW (pics)
Old Feb 12, 2009 | 05:43 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by Whippled 496
That thing looks f'in killer! Mine should be in next week.
Thanks Jim, you will have them in a day once they are shipped..You will be happy with the headers.. They look good. Only thing I am not a huge fan of is the SW tags they welded onto the front primaries. I think ima cut them off
Baltimore Whore
Originally Posted by GMCtrk
If the pipes fit very well together, it shouldn't take much to seal it off good at all. The aluminum foil acts like a good gasket.
They fit better then a glove
Old Feb 12, 2009 | 05:51 PM
charcold-bowtie's Avatar
my four in exhaust is alomost perfectly straight. I didnt order a d max exhaust or BS. I just took a slight bend into the joint were the pie hits the muffler and its about perfect. dumped of course...
GMCtrk's Avatar
Im glad to hear that John. I never had good luck with slip fit joints fitting properly.
Old Feb 12, 2009 | 05:53 PM
dlt76028's Avatar
according to your sig your aluminum foil trick doesn't work either.
jfwy
Old Feb 12, 2009 | 05:56 PM
BIRCHZ71's Avatar
damn that y pipe is f'n amazing!
Old Feb 12, 2009 | 05:59 PM
GMCtrk's Avatar
jfwy
But seriously, I got that trick from another member here.
If the pipes fit together snugly, there's no need for any foil.
The band clamps on my dynas seal perfectly because the pipes fit perfectly together.
Old Feb 12, 2009 | 06:02 PM
Baltimore Whore
I tell you what if there headers look as good as this Y pipe, they are the best deal out there(if they fit) I am still kinda impressed..
Also the slip fit, was actually kinda tight, took a little bit of a push to get them together..
CHARCOLD-
Do you have any pics od your exhaust, so I can get a idea..Also are you stainless??
Thanks gents
Old Feb 12, 2009 | 07:44 PM
Im running a 4nch i think its alumunized steel?, or galvanized peice of four inch back to a 4 inch deisel flo thru muffler. I will try to grab pics.
just for some sort of a reference, this is three inch pipe, with a bend. We just ran 4 inch straight through that same hole with no bend. muffler stayed in the same place. back when I had a 60e.
Old Feb 12, 2009 | 07:49 PM
If you see that first clamp, right by the wategate, there back is 4 inch. used a reducer to get on to it. All v bands. two total and exhaust removes pretty easily. I have a muffler with about a foot. ANd just a straight joint of 5 foot pipe.
