so i found out my ls6 springs arent going to work
Old Jun 8, 2008 | 11:40 PM
00ChevyScott's Avatar
Wearin' da big hat
Default so i found out my ls6 springs arent going to work
I was on the phone with shaner today and he said that my ls6 springs aren't going to handle the spring pressure this cam is going to create.
i think it was something like this
ls6 springs can handle 90 lbs closing, and 230ish lbs opening
and my cam needs like 130 lbs closing and at least 300lbs opening
I was going solely on cam lift, and didnt even think about spring pressure, so a big thumbs up to shaner for the heads up on that.
So if anyone has any patriot dual springs (new preferably) for sale, ill take em.
Old Jun 9, 2008 | 06:51 AM
viciousknid's Avatar
Where's the Beef?
Haven't thrown one of mine yet. And i'm not exactly good at staying out of the throttle.
Old Jun 9, 2008 | 07:00 AM
leochevy2001's Avatar
that's some good info to know right there.
Old Jun 9, 2008 | 08:49 AM
Wearin' da big hat
its not just about breaking a spring. without a tight enough spring, your cylinder heads could actually make contact with the valves. He said he has seen a couple LS1s he has rebuilt with marks on top of the piston because theyre running too soft of springs.
Old Jun 9, 2008 | 11:57 AM
budhayes3's Avatar
PT's Slowest Truck
Spring seat pressure is very important to consider when chosing springs, agressive lobes require more seat pressure Someone should make a sticky with this info since there have been alot of questions about what springs for what cam.
I've heard that the Crane duals are very nice also...
Old Jun 9, 2008 | 12:02 PM
Tootall's Avatar
the cam in your sig . . 216/220 - .525/.532 is that what's going in?
Old Jun 9, 2008 | 01:55 PM
Wearin' da big hat
yep, and i decided to go with some PAC beehive springs so far, im gonna try a research some more on those.
Old Jun 9, 2008 | 01:57 PM
Wearin' da big hat
i agree 100%, this is a really important issue that most people don't look into when buying springs, hell i didn't!
Old Jun 9, 2008 | 02:57 PM
LMSeven's Avatar
Good info, my current cam is 1 step under yours, the XR265. Now I'm mildly concerned lol. Later this summer I'm wanting to switch to a Comp 222/224 .566 .568, I'll probably switch to Patriot duals too.
Old Jun 9, 2008 | 03:33 PM
Where's the Beef?
Well if anything happens i'm officially holding you responsible for bringing it up.
