Snow Performance kit installed
Old Oct 30, 2005 | 08:05 PM
O3GMC's Avatar
12 Second Club
Default Snow Performance kit installed
Very nice kit, install was very simple. For now I am using straight denatured alcohol, although unless I can find some cheaper stuff, I'll be switching to methanol for ~$3/gal - I made a few part throttle runs, and one WOT, and it almost sucked down half a tank (see pics). Part throttle seemed to bog down a bit, but WOT felt very nice. Results of dyno tuning will be posted in the next few weeks. I'm going to get alot of before/after numbers - as-is, with injection, with increased timing, and most likely more boost (2.9 pulley).
Nothing like ice-cold boost
Old Oct 30, 2005 | 08:17 PM
greentahoe's Avatar
where did you put the controller?
Old Oct 30, 2005 | 08:18 PM
v8
17,16,15,14,13,12,11 Drvr
looks good jacob, are you going to make it to the shootout on the 12th, or the gtg on the 20th?
Old Oct 30, 2005 | 08:23 PM
I thought you were going to sell the truck. Very nice looking kit, great install.
Old Oct 30, 2005 | 11:37 PM
O3GMC's Avatar
12 Second Club
If you look close, its just to the right of the tank.
kevin - yes I'm planning on the 20th if I can get on the dyno before then.
Old Oct 30, 2005 | 11:46 PM
Deckhand's Avatar
badass man!
Old Oct 31, 2005 | 05:50 AM
ap2002's Avatar
looks good....
Old Oct 31, 2005 | 10:09 AM
Last Call's Avatar
TOTM: January 2007
You going to sell me the 3.0 pulley back? Im going to get a meth kit and want to pulley up a bit.
Old Oct 31, 2005 | 01:52 PM
O3GMC's Avatar
12 Second Club
Possibly, I'll see how things go on the dyno first. But with heat not being an issue, I see no reason not to use the smallest pulley I can (is 2.9 the smallest we can go or 2.8?)
I just called around and found a shop with methanol - $2.75/gal , so I'll be switching to meth or maybe a mix with water.
Old Oct 31, 2005 | 02:08 PM
Fogle07's Avatar
2.75 inch pulley
http://www.nelsonperformance.com/gmparts.htm
