Smoke... This can't be good...
Old Jun 8, 2006 | 01:18 PM
  #31
Lord Aries's Avatar
Thanks Yelo, I don't mind keeping the 5.3 intake because it has my 42lbs injectors in it and i don't won't deal with moving them... Maybe i will do the F.A.S.T. if i feel like i want something better...???
Thanks for the good luck Charged, it's gonna be fun when its done, that i am sure!
Time to start my list of any other parts i want to do while i have the motor out...
Old Jun 8, 2006 | 01:26 PM
  #32
quicksilverado's Avatar
What size is your turbo and how much power are you planning on making?
Old Jun 8, 2006 | 03:23 PM
  #33
Lord Aries's Avatar
it's a Precision Turbo, T-4 on both sides, .61Compressor and .81Turbine...They said it is rated to support up to 780hp... I am not looking for Parish Power, just ***** to the wall but able to drive it everyday... I was think the 12-15lbs of boost range. I know the turbo can produce 18lbs on my 5.3L with out a problem (found out when i had a little trouble with my boost ref point when doing some tuning last year)... If i need a bigger one then i will get a bigger one.
I think 550-600rwhp is an acceptable expectaion with the stroked 402 and 12-15lbs on it.?.?.? Or am i nuts?
Old Jun 13, 2006 | 07:28 PM
  #34
Lord Aries's Avatar
Its here!!! my 6.0L arrived today!!!!
Looks pretty good and it came almost complete, all it is missing is the Altenator, Belt and plastic cover... As soon as i get back from vacation next week i am tearing it down!!! Not too shaby for $1,500 shipped across four states to my door...
Old Jun 13, 2006 | 08:14 PM
  #35
Charged_5.3's Avatar
Congratulations Now are you make it a 408 or what
Old Jun 14, 2006 | 07:21 AM
  #36
Lord Aries's Avatar
402cid, i can get the Eagle Rotating assembley for a good price from a friend with connections... I will probably keep the stock heads and just have them ported out and a new valve train installed, some double springs and such... then a Custom Cam from my friends at Livernois Motor Sports... Put it all back together and go make some Vette's and Corbra's cry!
Old Jun 14, 2006 | 07:38 AM
  #37
You should be able to get 550-600 rwhp on 8-10 psi with a 402.
Old Jun 14, 2006 | 08:35 AM
  #38
Lord Aries's Avatar
Thats what I hear and I like what i hear!!! I am planning on running at least 10lbs... I would like to run 12-15lbs since my transmission should be fine and i have the fuel system to support it (42lbs Injectors and Walbro intank pump)... I wonder just how much boost the new motor could takew hen its done?
Old Jun 14, 2006 | 06:20 PM
  #39
One_Slow4.8's Avatar
im gonna gues it will take alot.. becuase you are going with forged internals correct??
Old Jun 14, 2006 | 07:33 PM
  #40
Lord Aries's Avatar
Yepper...
