Smaller cams make more power in 5.3 trucks
Old Mar 28, 2007 | 11:57 PM
TXsilverado's Avatar
Originally Posted by trever1t
He actually dyno'd 331hp Dyno chart , still very respectable and he also has the benefit of undoubtably one of the best tuners in the world
i dont give a damn about anyones dyno numbers. they are nice to jerk off to but would rather see track perfomance
edit: just read my own post and realized it could be taken harshly...that statement isnt directed at anyones specific dyno numbers, but ive seen quite a few cars/trucks put down massive numbers and run like a pile of crap, then others drop lower than average numbers, but run like a bat outa hell.
Old Mar 29, 2007 | 12:00 AM
Originally Posted by bgray
yah they sound like crayz good numbers...IVe got a 5.3 all the same mods, plus more...so im hoping to put down the same or more Id be happy
i dropped 277hp with my full bolt on LS1. its all about picking a generous dyno. dyno's are a great tool, but should be only used as a tool.
Old Mar 29, 2007 | 12:15 AM
blake2kz71's Avatar
very true
Old Mar 29, 2007 | 12:46 AM
Sport Side's Avatar
The larger cam might make more power if you could spin it high enough to take advantage of where the power band will be.
On the other hand the smaller cam will make more usable power at a lower rpm.
There it is...
Old Mar 29, 2007 | 03:06 AM
ricoc's Avatar
I noticed even with a "small" cam the gains don't show untill after 4000rpm
http://i11.photobucket.com/albums/a1...2007_00006.jpg
Old Mar 29, 2007 | 06:55 AM
ThunderZ28's Avatar
12 Second Club
agreed
Old Mar 29, 2007 | 09:19 AM
Mr. Sandog's Avatar
The cam in the 5.3L in my Avalanche (with a stock converter) was a 205/212, .544/.550, 114+4, and it added 15-20 RWHP/RWTQ across the entire powerband. You won't hear many guys admitting they want a cam is this small, but I don't (and didn't) care what other people think. It gave me the exact results I was looking for -- more power under the curve from idle all the way to redline.
If you want to race your truck all the time, have a high stall speed converter, and/or like living in 2500-3000 RPM and above, then you should get a bigger cam. However, if you are like me and want all-around, daily-drive power, then you might want to consider something a little more mild.
Old Mar 29, 2007 | 09:29 AM
02sierraz71_5.3's Avatar
Originally Posted by jarednut4ever
I talked to some speed shops and they told me in a ex cab 4x4 5.3 that the 210-218 duration cams make more power then the 224 228 cams. I thought that was interesting because I always thought bigger made more power. They said that in a 5000 lbs truck the 224 cam will be a complete terd and a 210-218 will be an animal all the way to 6000 rpm. Let me know what you guys all think about this. I Know I know another cam thread. But you opinions are apreciated anyways, Thanks, Jared
Thats because of the truck intake; the intake is very important and decides the power band that the cam should be matched to. If you are staying with the stock intake you dont want a cam thats gonna make power past 6000 even though its pulling out there its cut the head off the good part of the cam.
RPM range can always be matched with verter speed if your runing an auto.
steves86ta
Jul 28, 2015 10:21 AM
black6spdz
Jul 16, 2015 01:32 AM
06 4.8
Jul 15, 2015 07:17 PM
lxcoupe
Jul 10, 2015 05:11 PM
Sbrown06
Jul 9, 2015 09:21 AM
