Smaller cams make more power in 5.3 trucks
Originally Posted by trever1t
He actually dyno'd 331hp Dyno chart , still very respectable and he also has the benefit of undoubtably one of the best tuners in the world
edit: just read my own post and realized it could be taken harshly...that statement isnt directed at anyones specific dyno numbers, but ive seen quite a few cars/trucks put down massive numbers and run like a pile of crap, then others drop lower than average numbers, but run like a bat outa hell.
Originally Posted by bgray
yah they sound like crayz good numbers...IVe got a 5.3 all the same mods, plus more...so im hoping to put down the same or more Id be happy
The larger cam might make more power if you could spin it high enough to take advantage of where the power band will be.
On the other hand the smaller cam will make more usable power at a lower rpm.
I noticed even with a "small" cam the gains don't show untill after 4000rpm
http://i11.photobucket.com/albums/a1...2007_00006.jpg
i dont give a damn about anyones dyno numbers. they are nice to jerk off to but would rather see track perfomance
The cam in the 5.3L in my Avalanche (with a stock converter) was a 205/212, .544/.550, 114+4, and it added 15-20 RWHP/RWTQ across the entire powerband. You won't hear many guys admitting they want a cam is this small, but I don't (and didn't) care what other people think. It gave me the exact results I was looking for -- more power under the curve from idle all the way to redline.
If you want to race your truck all the time, have a high stall speed converter, and/or like living in 2500-3000 RPM and above, then you should get a bigger cam. However, if you are like me and want all-around, daily-drive power, then you might want to consider something a little more mild.
Originally Posted by jarednut4ever
I talked to some speed shops and they told me in a ex cab 4x4 5.3 that the 210-218 duration cams make more power then the 224 228 cams. I thought that was interesting because I always thought bigger made more power. They said that in a 5000 lbs truck the 224 cam will be a complete terd and a 210-218 will be an animal all the way to 6000 rpm. Let me know what you guys all think about this. I Know I know another cam thread. But you opinions are apreciated anyways, Thanks, Jared
RPM range can always be matched with verter speed if your runing an auto.
