sluggish after header install
Old Oct 5, 2011 | 12:58 PM
Sanster's Avatar
Default sluggish after header install
put a set of ceramic coated headers on my buddies 04 seirra 5.3 and now its really sluggish until it warms completely up. exhaust is long tubes with off road Y and 3 in all the way back with a magna flow muffler. heard of people putting corvette O2's in them and that helps. can i get some imput here on what we should do to it?
Old Oct 5, 2011 | 01:28 PM
nickleahy23's Avatar
did you retune it and turn off the rear 02 sensors?
Old Oct 5, 2011 | 02:34 PM
Sanster's Avatar
no retune but we did shut off the rear O2's with HP tuners
Old Oct 5, 2011 | 03:09 PM
Mangled03gmc's Avatar
Baltimore Whore
You should not be running the truck hard untill it is def up to op temps. Not good on parts.. LT's will usually result in a slugish or slower low end, but make up on the mid and top end.. A retune would take that feeling away..
Old Oct 5, 2011 | 03:17 PM
Sanster's Avatar
Ill have to tell him all of that. Thanks Guys
Old Oct 5, 2011 | 05:22 PM
That's normal after a header swap as mentioned early. Funny as it may sound it is too free flowing and hurts your low end torque it does not have enough back pressure. There is a fine line to walk and once you start playing with it there are some inherent sacrifices you'll find along the way.
BUT: A tune definitely needs to be done. Headers completely change the airflow characteristics and aggarvates the stock tune.
Old Oct 6, 2011 | 06:53 AM
gnd111's Avatar
Long tubes by nature make better low end and short tubes make better upper...
Obviously a re-tune would be needed if either is added but the long / short relation to lower end torque hasn't changed.
Old Oct 6, 2011 | 07:02 AM
14psisupra's Avatar
Obviously a re-tune would be needed if either is added but the long / short relation to lower end torque hasn't changed.[/QUOTE]
since when?
Old Oct 6, 2011 | 07:12 AM
gnd111's Avatar
since when?[/QUOTE]
Long tubes have always made better low end torque on NA applications.
Did it change recently? I am certainly not an expert but any vehicle i have had always makes better low end with long tubes. Both my carbed and FI vehicles.
I am not sure about upper rpm HP though.
Old Oct 6, 2011 | 07:27 AM
gnd111's Avatar
LS1 Header Test - Evaluation and Dyno Numbers - Car Craft Magazine
Some decent info with tests...
