Slight tapping noise that comes and goes
Old Nov 21, 2009 | 03:18 AM
slowtahoe00's Avatar
Registered User
Default Slight tapping noise that comes and goes
I have a 2000 Tahoe NBS and it has 112K on the clock. Recently when I first start it, it makes a tapping noise which goes away within 10 seconds. I doubt that its bottom end noise because I heard that one before on my old car and it didn't go away. I'm thinking that it's a lifter gone bad but I could be wrong. I have put new plugs and wires in it thinking that it would fix the problem (also getting the flashing SES light sometimes) but it did no such thing. I need help!!! I forgot to add that the codes that I pulled were the O2 sensor, and random misfire cylinder #2.
Last edited by slowtahoe00; Nov 21, 2009 at 03:20 AM. Reason: addition of comments
Old Nov 21, 2009 | 09:29 AM
budhayes3's Avatar
PT's Slowest Truck
It could be a lifter, or it could be the infamous piston slap that is characteristic of the GM GENIII engines. The piston slap is very common and GM states that no repair attempts should be made as it won't harm anything. The codes are a different story, you need to diagnose the misfire and see if it has anything to do with the O2 sensor code, or if you have a failing O2 sensor...
Old Nov 21, 2009 | 04:02 PM
Registered User
Thanks for the input, I was kinda leaning towards the O2 sensor but I never imagined that it would cause a misfire the way it has been.
Old Nov 21, 2009 | 05:43 PM
fastnblu's Avatar
I see Billy beat me to it. :nunchuk1:
Old Nov 21, 2009 | 06:19 PM
Gregory's Avatar
If you have a cold air intake they can throw codes. If that is the case, then adjusting the MAF table will fix it. I also have the lifter tapping that makes the engine sound like a sewing machine. I'm using better quality synthetic oil to fix it. Try RISLONE oil treatment in a yellow quart bottle at an auto parts store and see if it helps.
Old Nov 22, 2009 | 10:21 PM
hodge9386's Avatar
12 Second Club
lucas works good on mine, u can also try a little thicker oil, i been thinking about trying that z-max oil treatment, i herd it works good.
lukn4trbl355
Oct 21, 2015 11:19 PM
JordanH
Oct 3, 2015 03:59 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
lxcoupe
Sep 25, 2015 12:36 PM
