Single walbro inline 255lph flow question
Old Oct 29, 2015 | 11:04 PM
Mzay's Avatar
Registered User
Default Single walbro inline 255lph flow question
Hi, I have a 2001 silverado lq4, that I installed a turbo on several months ago. Anyways, I was wondering if a single inline walbro 255lph is enough to support around 10 psi of boost. I had it laying around from another project, so I decided to run it. Before I take it to get tuned, I want to be sure that it will flow enough fuel. I'm running the stock fuel pump in the tank, and 60lb injectors. Any one know if it'll work? Or should I get a 300lph+ fuel pump
Old Oct 30, 2015 | 02:16 PM
zblee's Avatar
This all depends on how much power you are creating, you can either get the pump that you need based on current injectors or you can get a pump based on the power you will be putting down.
here are a couple of calculators I found by googling 'fuel pump calculator'
Fuel Pump Calculator | Fuel Calculators | Resources | DeatschWerks
Fuel Injector and Fuel Pump Calculator
nabozny21
Oct 17, 2015 07:47 PM
KleanKustoms
Oct 14, 2015 09:50 PM
pewter00
Oct 6, 2015 06:37 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
