Cam help!--2006 vortecmax 6.0 (lq9)
Old Oct 29, 2015 | 01:32 PM
Scain33's Avatar
Registered User
Default Cam help!--2006 vortecmax 6.0 (lq9)
Need some expert help on what cam to go with! I have a 2006 GMC Sierra 6.0 lq9 with the 4l70e tranny and 4.10 gears. Only mods so far are shorty headers, cold air intake, magnaflow dual exhaust cats still on, and superchips which will be swapped for a custom tune thru hptuners. I'm looking for a setup that is reliable and could still be a daily driver if wanted to be. I want a well rounded setup that helps with all around in the Rpms and a better sound at idle, open to the idea of a stall also. Would like to keep mods under $1700. Open to all opinions and any help!
The $1700 is for parts only I have help on the labor and tuning side of things.
Old Oct 29, 2015 | 01:54 PM
chadjcompton's Avatar
longtubes, stall, cam, and springs is definitely do-able under $1,700.. i just bought a stall ($450) cam ($400) and springs ($250) for my VMax.. i'd put that little extra money into re-doing your exhaust with the longtubes.. that 6.0 loves to breathe, so let it.. i love my truck, should be putting everything in plus injectors in a week or 2...
Old Oct 29, 2015 | 02:04 PM
Scain33's Avatar
Registered User
What Are the specs for the cam/stall/springs your going with?
Old Oct 29, 2015 | 02:05 PM
Scain33's Avatar
Registered User
And I was proposing the idea of electronic exhaust cutouts...
Old Oct 29, 2015 | 02:15 PM
Atomic's Avatar
I have a gauge for that
This thread looks familiar...
The cutout wont help power any unless you have the stock muffler or something, but it will make it much louder.
Old Oct 29, 2015 | 02:19 PM
Scain33's Avatar
Registered User
Just trying to get different opinions, def appreciate the input tho!
Old Oct 29, 2015 | 02:24 PM
Vortec350ss's Avatar
It can most definitely be done for that cost. And your exact needs can be met with a cam as well.
Old Oct 29, 2015 | 02:28 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
If you would like, give us a call at (512) 863-0900. We would be more than happy to go over your combination and goals and point you in the right direction.
Lonnie
Old Oct 29, 2015 | 06:26 PM
I have a custom spec cam which is 219/227 114+3 , springs are .650" lift beehive, and 3200 stall from circle d.. If i were you, I would consult with someone to get a custom spec specific for your truck.. The best cam for your truck won't necessarily be the best for mine cause there's so many variables that effect a cam.. Like what size tires your running and what gears you have and so on and so forth.. But if you wanted to go with the off the shelf cam kit then BTR's stage 3 truck cam is a good one, my buddy just got one
Old Oct 30, 2015 | 09:05 PM
Closer_2001's Avatar
LPE GT2-3 with gears/stall to move those big tires. Could always go FI later on top of it...
La Grey 1
Sep 21, 2015 11:07 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
nickrench3
Sep 17, 2015 08:48 AM
lsxperformance
Sep 15, 2015 10:22 PM
