Shrader Valve Help!
Does anyone know what size the shrader is? Is it 4an? Also is it male or female coming off of it? Im trying to figure out how im gonna run my Hobbs switch.
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by ZYA_LTR
Just don't forget to disconnect the battery, and have a rag ready to drain off the pressure before you remove the valve stem.
Originally Posted by Chingon
Take the gas cap off too.
What is that gonna do??If you want to keep from spewing gas from the rail when you pull out the schrader valve, pull the fuel pump relay then crank the truck and let it die. Taking the gas cap off is not going to relieve the pressure in the fuel rails.
btw.. a female 4AN is what you need to connect your hobbs switch to the fuel rail at the test port.
