should i send these headers back?
Old Sep 6, 2016 | 02:36 AM
  #21
climb-101's Avatar
Nice. Now you just need to order up a custom flange. If you can't order one than I'm sure a machine shop could cut one down. Might need to make some tappered washers also so the bolt sit flat on the flange.
Old Sep 6, 2016 | 07:52 AM
  #22
TXsilverado's Avatar
Planning to just order a set of flanges from arh and have a local machine shop mill the flanges and countersink the headers at the right angle.
Old Sep 6, 2016 | 08:56 AM
  #23
climb-101's Avatar
That's a good idea. Should make things simple and solve the problem.
Old Sep 8, 2016 | 12:06 PM
  #24
I guess this is not as easy as I originally thought. Talked to 2 machine shops about angle decking the header flanges down and they aren't interested. ARH hasn't replied to my last e-mail in 3 days. finally called my local head porter and he is wanting to call me back later today. fingers crossed that I can make this happen without breaking the bank.
Old Sep 8, 2016 | 01:09 PM
  #25
climb-101's Avatar
Got any buddy's with a Bridgeport mill? I would just tack weld it onto another block so it was flat, setup the block offset on the table and mill it down. Prob take 1/2 hour. Then I would weld the flanges together, clamp the header to the table, and use an end mill to recess the holes flat.
Old Sep 8, 2016 | 01:43 PM
  #26
I'll send it all to you then LOL.
Old Sep 8, 2016 | 02:12 PM
  #27
Atomic's Avatar
I have a gauge for that
You could do it with a belt sander and a steady hand if you really had to
Old Sep 8, 2016 | 02:46 PM
  #28
climb-101's Avatar
Ya you could use a belt sander, just build a jig on either side of the flange as a guid.
Old Sep 8, 2016 | 03:28 PM
  #29
Vortec350ss's Avatar
Wont that also lift the collector? I would be nervous about it sitting too high and hitting the body then.
Old Sep 8, 2016 | 03:29 PM
  #30
climb-101's Avatar
He is moving it left to right not up and down
