Should I go from 9psi to 11-12psi?
Old Apr 5, 2005 | 04:24 PM
chris99gmc's Avatar
Originally Posted by greentahoe
I would invest in a FMIC before trying that amount of boost. You will put quite a bit more stress on the motor and may not see much more power due to the higher IAT's as TurboBerserker mentioned. Do you have logging software? I would do some logs of your IAT's before running that kind of boost on a day to day basis.
I got my OBX FMIC for $250 and $35 shipping. Stainless pipe was a little over $200 I think, but I should have quite a bit left over. I think I spent a little under $100 for high temp silicone couplers and T bar clamps.
Now if I could only put it together
.... I would look into a few other mods if you still aren't happy with the power you are getting, don't just crank the boost **** up yet. I'm in the same boat as you are. My power isn't near what I want it to be. Look into a good cam after you get that FMIC on there. Also, e-fans help free up power as well.
also, do you have springs on that thing yet?
Old Apr 5, 2005 | 04:42 PM
Weedo's Avatar
Good info guys...
Green, did you have to also invest in electric fans?
Old Apr 5, 2005 | 04:47 PM
Weedo's Avatar
Honestly? I'll never have enough power!
In reality, the thing is an absolute beast. But I figure, why leave power on the table if I can have it for free?? Yes, I do have springs/pushrods in now.
Ok, so you've all talked me into sticking around 9psi. I'm sure once the Trans/Stall goes on in 2 weeks it will be an entirely new toy! Then the next project will be the FMIC/Fans. Oh my poor wife...
Old Apr 5, 2005 | 05:11 PM
greentahoe's Avatar
Originally Posted by Weedo
Good info guys...
Ya I did. It wasnt bad and the engine bay is SO much cleaner. I got the harness from Nelson and he threw in a switch so I can turn them on whenever I want.
470 in that thing must be sick! Ive got another 5K in mods I need and that doesnt include the shortblock. I hope to be damn near 600 by this time next year, but that is easier said than done.
Its only money right
Old Apr 5, 2005 | 09:36 PM
Weedo's Avatar
Yep, 470, and that's at 30% drivetrain loss from the AWD (from what I understand). That puts me at 670 "crank" HP. Now if it just wasn't 5700lbs it would be a total animal!! I need to find one of those "405 HP" Z06 badges and have it made to read "670 HP"!
I hear you on the $$$$ part. There's always something else that I'm finding I "need" to buy. I think with a bit more tweaking I should hit around the 500awhp mark at 9psi. Right now I'm tuned way rich on the Meth. After that, the FMIC will be next along with the eFans, maybe a bit more boost, and low-mid 500's. THEN I'll be done.......riiiiiiiiiiighhhhhhht.........
Old Apr 6, 2005 | 09:41 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
24% from AWD is what I've always heard. 30% seems really really high.
The new tranny will help -- did you get a PI with a "turbo" stator?
And get some damn efans!!
Old Apr 6, 2005 | 09:51 AM
haynSS's Avatar
Weedo, are you consistant on your low boost (5lbs)?? I was seeing an issue where my boost goes to 11-13 without being on high in the boostcontroller.
Old Apr 6, 2005 | 10:33 AM
Weedo's Avatar
I'm basing that on what both shops (Tuner and Dyno) are telling me. They figure around 22% for a rear wheel drive truck (more than a car). Adding the all-wheel drive puts it at least at 30%. Either way, the numbers don't mean much, it's the fun factor!
I ended up calling PI and having them custom build whatever they thought was best. I believe it's the 10.5" multi-disc 3 plate. He said he would put the stall in the 2900-3000 range. I gave him all the stats on the truck: power, weight, etc... and he knew exactly what he was going to build. My guess is that he's using the Turbo Stator if that's what he should use.
haynSS
I haven't had that problem with the 5psi setting. I've only had it on that setting a couple of times. On the dyno I watched it go from 5psi to 6 or 7 but that was on the shift which is normal with a slipping trans. Seems odd yours would go THAT high!
GXPJAY
Feb 13, 2022 08:15 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
stealthperf
Sep 18, 2015 05:51 PM
