Should I get the Summit UD pulley?
Old Feb 2, 2009 | 10:16 PM
Hugger's Avatar
10 Second Club
Default Should I get the Summit UD pulley?
I am thinking about getting one of these. Does anyone have one? I have an ASP on the camaro but thought about trying the summit pulley since it is less expensive. Does anyone know how much it weighs? I hope it weighs less than the stock pulley. Any reason I shouldn't buy one?
Josh
Old Feb 2, 2009 | 10:20 PM
Mangled03gmc's Avatar
Baltimore Whore
I am sure it is less then the stock one. Also ALOT of the **** offered by summit or jegs is pretty decent things.. I say go fer it
Old Feb 2, 2009 | 10:30 PM
ChevyTruck's Avatar
something else
Most of Summit parts are a name brand part with a Summit sticker or stamp. Like there air filters are K&N filers.
I am sure that Summit will do just fine.
Old Feb 3, 2009 | 09:58 AM
Hugger's Avatar
10 Second Club
Well I ordered one. I will let you all know how it works out. It will probably be a while before I put it on since I will most likely do a cam swap at the same time.
Josh
Old Feb 3, 2009 | 11:32 AM
CI DENALI's Avatar
The Summit U/D Pulley is smaller but not much lighter (if any) than the stocker, since it is steel instead of aluminum. But, it appears to be a good quality piece. I installed one on a friends 99 Vette about a year ago and it's still in one piece, which is better than some I've seen in the past - like the Whisper lightweight Aluminum which came apart on my old '98 camaro. I replaced that with a ASP and I have to say that the ASP to me is the best and probably the most popular one out there. The weight shouldn't be a problem, as it's the decreased drag from underdriving the accessories that gives you the HP gain, and I think a harmonic damper (which this is) needs to have a bit of weight to work properly, IMO. For an all out/race build, the ATI would be the best.
Old Feb 3, 2009 | 10:01 PM
transamdave's Avatar
+1 Summit brand is just sas good as any, plus it saves a lil money. I used one of there cams and loved it.
Old Feb 4, 2009 | 08:11 PM
greenz71's Avatar
A question for those more knowledgeable than me(about everyone according to my wife), which one will fit my truck?(03 silv 5.3)
Old Feb 4, 2009 | 08:13 PM
RandomHero's Avatar
I couldn't find one on Summit's website for our trucks. Anyone care to throw out a part number or link?
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
