Shortblock and heads are here
Old May 8, 2004 | 12:08 PM
Default Shortblock and heads are here
I just got the build sheet on my new shortblock,it's a 403 with Diamond dished pistons,Eagle crank,Scat 6.125" rods,steel main caps.ARP main and head studs and a Comp 228/234 .588/.598 115+4 cam.The heads are TEA 6.0 stage 1.5 with Comp 977 valvesprings,titanium retainers and Comp Pro Magnum 1.75 rocker arms.I'm also going to run Comp R lifters and push rods.With a .054 compressed head gasket it should have a 8.96:1 compression ratio.I'm planning to run it with my Radix setup and a Pro M maf.I guess I'll find out just how much power Radix setup can flow.
Old May 8, 2004 | 12:17 PM
04sierra's Avatar
Sounds good, let us know the results. I guess that Tahoe of yours is going to be even faster!!
Old May 8, 2004 | 07:05 PM
BigTex's Avatar
Man, you do know that with those rockers you'll lifts of .605 and .615. What kind of lifts do those 977 springs handle? I had my heads setup with 978 springs.
Old May 8, 2004 | 07:16 PM
What gasket did you end up deciding on? Was the 9199 bore big enough?
Now you can get those 57lb injectors in and tell me what you had to do to get them on that Radix rail.
How long before it's running? And, is the Eagle crank keyed? The Callies crank I'm getting is, just curious.
Old May 8, 2004 | 08:34 PM
The Comp 977s are set for .670 lift and I had the crank and stock pulley keyed.I hope to have everything togather and installed in the next 2 weeks.TEA seems to like the 977s better than the 978s.
Old May 8, 2004 | 08:36 PM
Which head gasket did you decide on?
Old May 8, 2004 | 08:42 PM
The 9199 PT,it compresses to .054 and will fit my 4.005 bores.
Old May 8, 2004 | 08:44 PM
Thanks.
Old May 8, 2004 | 08:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by BenKey
Thanks.
Taking notes?
Old May 8, 2004 | 09:01 PM
BigTex's Avatar
Ben, didn't you use the felpro 9199 last time?
