Short belt?
Old Apr 26, 2003 | 12:43 AM
CashDudeHomie's Avatar
Default Short belt?
How do you bypass the power steering? It looks like the belt would hit the left side of the PS pulley. Anybody done this?
Old Apr 26, 2003 | 03:35 PM
BigKID's Avatar
Default Re: Short belt?
I haven't done it myself, but I know you have install and additional idler pully to route the belt properly. Maybe Lotsofun will enlighten us a little more since he has done it.
Old Apr 26, 2003 | 08:23 PM
Changing belts on a hot motor in the dark, before you can drive home sounds like pain in the a**.Especially if you're only gaining what 1 to 2hp.
Old Apr 27, 2003 | 08:16 AM
EricB's Avatar
When we short belt, the belt just slightly touches the power stearing pump pullie. It turns slightly but under rpm, i don't think it will effect you. If you get and underdrive pullie, then it will not touch the power stearing pullie. I don't know if it really helps the truck, ( i never did it on mine) but i do have a couple of friends that are running good numbers that do it. But like someone said, It does get hot around that engine trying to change that belt... I suggest a pair of long sleeve and some good gloves..... Hope i helped and have fun getting burned....
AdaMax
May 16, 2016 11:35 PM
gmcyukon
Oct 5, 2015 06:20 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
