to shiftkit or not to shift kit
#21
Originally Posted by moregrip
assembled off the shelf valve body?
also do these mods apply to the 4L80E?
Hitman, one more for ya. What is a reasonable price to have someone install the FLP. It seems that at this point it would make more sense to wait till my tranny takes a dump and just slap in the FLP. Ive already got 70K on my transmission. Thanks for all the info!!!
#22
Originally Posted by revolution
if you have a grinder, do it yourself. its not that hard. its kinda like legos. watch the video a few times - but follow the written instructions. the hardest part for me was taking the snap ring off.
hitman: have you heard/seen any broken plastic acc. pistons? im worried now.
and the 4L80E is pretty different in comparison to the 4L60E. It really just needs a good built VB and a cooler, should take a good amount of power then.
#23
Originally Posted by greentahoe
No, an assembled performance transmission. Ive heard the 4L80 is good to like 600hp with just a shift kit.
$250-400 again for an install. Depends on the labor per hour. Typically it's about $70/hr around here.
If you've got 70K and plan <450rwhp then that tranny from them should be a good setup. If you plan much more power than that, I'd consider a 4L80E swap...
#24
Hit Man X, not quite sure what your asking....but if you mean that your going to be building some pre fabbed upgraded valve bodies where all I have to do is unbolt mine and bolt yours up, then yes I would be interested. Please don't take this the wrong way but how qualified are you at doing this?
#25
Yeah, I've been thinking on building some assembled VBs here. 99silver5.3 wants one pretty bad
If you like it, pay for just the shift kit and send me your stock VB in return. That's the plan until I could get enough out there.
#27
I might very well be interested, whats the deal with billet servos? is that whats needed in a 4l80e? as well
Billets are for the 700R4/4L60E trannies (well they got them for the 200-4R, AOD, etc
The 4L80E doesn't use a band for gears (it has one but it's like a coast or reverse band, I can't remember right now I haven't slept in close to 34 hrs) it uses clutches for each gear. Forward for 1st, intermediate for 2nd, direct for 3rd, and OD for 4th.
So there is no need for an apply piston of a band to make a shift. Hope that makes sense...
#29
nope, not to me, but I don't want to keep you awake any longer....I'll do a search and try to edjumacate myself, thanks hitman!
Oh well, the 4L80E is bigger, stronger, and better than the 4L60E but takes more power to run.
It's okay, I don't sleep much anymore.
#30
Hitman helped me through my install, well gave good advise to listen too, flyer too. There both well educated in the art of Shitkits, I mean shiftkits.
If Hit does offer a prefabbed valvebody, then go with it, I would trust his work.
