shift kit w/ 4wd
Old Aug 13, 2002 | 09:19 PM
badpewter-z's Avatar
LS1TECH Sponsor
Default shift kit w/ 4wd
my question is will it help and will it shift good or bang alot
i hate the way its shifts so smooooooooooooth
i put in my hpp3 last week and it helped,love the shift points but firmness and quickness not where i want it, i'd like to be able to scratch 2nd.
i know tqm <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> isnt helping me but dont have a laptop to run ls1edit
i had a tci kit in my old car, i know it wont be the same but I WANT QUICK FIRM SHIFTS again
Old Aug 13, 2002 | 10:04 PM
BigJ's Avatar
Default Re: shift kit w/ 4wd
Not sure about the shift kit, but I have heard good things about it. I got the corvette servo last weekend, and I love the shifts now. It firmed up 1st and 2nd shifts at part-throttle a lot, and the 1st to 2nd shift at WOT is great. It just glides into second now, unlike before it would shift really slow and weak. I am very happy with it. Just something else to think about. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 13, 2002 | 10:05 PM
CashDudeHomie's Avatar
The Corvette servo is like 20 bucks and takes 20 minutes to install and it will firm it up real nice especially with the Hypertech tuning. That's what I have. But if you want a shift kit, that would be better, but more expensive and hard and time consuming to install.
Old Aug 13, 2002 | 10:07 PM
BigJ you beat me by less than a minute!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 13, 2002 | 10:08 PM
BigJ's Avatar
<img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 13, 2002 | 11:29 PM
dutch 99 chevy's Avatar
what all is involved with putting in a Corvette servo
Old Aug 13, 2002 | 11:43 PM
Let your truck cool off, then remove the heat shield on the right side of the transmission by the cat. It's 2 10mm bolts, you have to use a socket for these. Then you can see the round housing and there are 2 slots in it. There is a ring holding it in. I used a screwdriving and tapped it up there to remove the retainer. Then very carefully pry the piece out with the screwdriver without scratching it or breaking the seal (just incase the new one breaks when reinstalling you will have a spare.) Now I did not do this, but remember the order you pull the parts out. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Just start pulling stuff out, on one piece I had to remove a retaining clip and a washer and pull it apart while still under the truck because it would not come out, since you are working so close to the tunnel. When you have all the stuff out one piece has a retaining ring and then a cover and a spring under it that you have to transfer to the new part. You can use a C clamp or if you don't have one just put something on it and step on it to remove and reinstall the retaining ring. Then put new seals on and put vaseline on them and reinstall everything like it came out. The tricky part is doing to part with the washer and then putting the ring back on it since there is not much clearance. Then it help the get a buddy to use some kind of tool to push the whole assembly in while you reinstall the retaining ring. It sounds complicated but it isn't. You can find pics on the internet if you go to a search.
Oobray
Jun 13, 2022 03:38 AM
Blackrat48
Aug 16, 2015 11:56 AM
lycominghunter
Aug 15, 2015 12:26 PM
Ammadien
Jul 22, 2015 08:50 PM
zaathur151
Jul 6, 2015 10:57 PM
