Shift Kit and Pulley Recommendations
Old Sep 26, 2003 | 02:24 PM
whitez71's Avatar
Default Re: Shift Kit and Pulley Recommendations
The TCI kit looks pretty complete. You can view the instructions on their web site. It says that you have to drill out the seperator plate and swap out some acummualator springs. It also says the servo is the same on as on the vette.
Old Sep 26, 2003 | 02:34 PM
Hit Man X's Avatar
Yeah sorry, you are right about it being more indepth than the B&M kit. It looks between a B&M and TransGo. The servo they sell is like $15 from KDS Performance too
Old Sep 27, 2003 | 05:06 PM
Silvette_02's Avatar
So with my combo, just crank pulley or alternator too?
Also, what is the best place to buy these parts from? Would like to support a sponsor if at all possible.
Josh Hucks
Old Sep 28, 2003 | 12:11 PM
Hit Man X's Avatar
Josh Hucks
I'd get the crank and overdrive alt pulley. The OD alt pulley is 1.75"...very tiny and it will spin the alt faster at idle to help undercharge
Old Sep 29, 2003 | 01:10 PM
Alright thanks a lot.
Where should I buy these parts from?
Josh Hucks
Old Sep 29, 2003 | 03:01 PM
Hit Man X's Avatar
Josh Hucks
www.rpmoutlet.com has them
Old Sep 29, 2003 | 04:00 PM
Grey Silver's Avatar
11 Second Club
I've got a trans go in my truck w/ a built transmission and it shifts hard all the time. I just learned that you don't need a shift kit w/ a computer controlled transmission. It can be programmed to shift any way you want. Check out Westers web site. I think he's got a program that's specific to the 4l60e. I'd like my truck to shift easy when I'm driving easy and snap my neck when I'm gettin on it.
Old Sep 29, 2003 | 04:18 PM
11 Second Club
Yep, Westers has it and you don't have to take the trans apart. http://westers_garage.eidnet.org/scprice.htm
Old Sep 29, 2003 | 04:27 PM
Hit Man X's Avatar
They just raise line pressure...
A TransGo rebuilds the valve body. A clean valve body shift is FAR nicer than a high line pressure shift. I swear by TransGo shift kits and use/install them in every vehicle I own that will take one.
Mine shifts easy when cruising...the will bark 285 ATs out back at WOT
Oobray
Jun 13, 2022 03:38 AM
1slwgto
Aug 16, 2015 06:40 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ammadien
Jul 22, 2015 08:50 PM
zaathur151
Jul 6, 2015 10:57 PM
