Sensor above intake manifold.
Old Nov 6, 2014 | 04:45 PM
85LSXTRUCK's Avatar
Default Sensor above intake manifold.
I am doing a swap with a 5.3 and there is a sensor on the front top of the intake with a plastic hose/tube going to the rear, do i need this or can i disconnect it and how?
Old Nov 6, 2014 | 05:43 PM
FFDP's Avatar
What year intake?
I know for 99-06 intakes "NBS", the MAP sensor is on top and the nipple with the hose going to the rear is for the rear valve cover breather/pcv dealio. There is also the brake booster hose on the very back.
Old Nov 6, 2014 | 08:25 PM
01silvy's Avatar
That is your evap stuff. If you disconnect it it will just set a SES light. It injects fuel vapors from the charcoal canister at specific times, like to aid cold start and such.
Old Nov 7, 2014 | 12:48 AM
That's evap purge solenoid just re install it on the new motor no need to do away with it as it has 0 effect on HP
Old Nov 7, 2014 | 02:49 PM
85LSXTRUCK's Avatar
Its an 03 5.3. Its going into a 85 chevy truck that dont have any evap crap on it and wondered what my best way to deal with it. I kind of figured it was for evap but wasnt sure how to remedy it. Any swap guys have any answers.
Old Nov 10, 2014 | 06:50 PM
MaDChevy95's Avatar
Just plug the hole like you would be deleting it no problem.
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Aboss
Aug 11, 2015 09:05 AM
Suburban2500
Jul 14, 2015 02:10 AM
Hmguyton
Jul 7, 2015 03:29 PM
